Home > Technical > Measuring front wiper sweep
excossack
From another post my drivers side wiper sweep goes too far and wiper the windscreen rubber.
A video link was posted to Britannia Restorations that showed you can alter the angle of sweep by altering/changing the wiper cog.
Whats the best way to measure the current angle of sweep?
Protractor lined up with the wiper arm ?
Protractor lined up with the spindle for the wiper ?
and measure to the max sweep position? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #935647 30th Dec 2021 3:42pm
rallysteve
I would use a bit of trigonometry if i was you.
Get a chalk marker, put a dot at the end of the blade in the park position. Move the wiper to the extents of its sweep and put another dot. Now you can use a tape measure to measure the distance from the centre of the spindle to either dot, and the distance between the dots. You know have an isosceles triangle with all three side lengths known.
You can then either divide that triangle into two right angled triangles and use pythagorus' theorem or just use the sin/cosine rule to work the angle out.
Sounds worse than it is Shocked
Post #935649 30th Dec 2021 3:49pm
geobloke
Yup I would say the easiest way is by protractor or OS orienteering compass. Make sure there is no slop in the system before doing the test by lifting the wiper arm and twisting it. If it is loose it might need a little tightening first.
Post #935650 30th Dec 2021 3:51pm
excossack
Cheers both. I will take a look when its not peeing down! 1999 Defender TD5 110
Regards
John M0VAZ
Post #935658 30th Dec 2021 4:54pm
geobloke
Get out there John you're not made of sugar ya know... Rolling with laughter
More seriously it is the perfect time to work out the angles from the drivers seat. Set the wipers going and take a compass out with you. Thumbs Up
Post #935663 30th Dec 2021 5:44pm
Dinnu
Maybe you can measure the chord length at the top of the wipe... you know the distance from the wiper spindle to the tip of the wiper.. and do some math... in the age of the lazy, you can use one of the online calculators such as this:
(only need to measure two dimensions, keep the rest blank)
https://www.handymath.com/cgi-bin/arc18.cg...wFormula=0 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #935676 30th Dec 2021 6:35pm
Linds Hanson
Sounds like you have the wrong wiper motor drive gear if its travelling too far, the pre 2002 models use a different ratio drive to wheel box then the post 2002 models
Post #935685 30th Dec 2021 7:33pm
ickle
If the circlip falls off the crank on the motor spindle, the bush falls out and centrifugal force effectively increases the sweep of the spindle and the travel of the rack and hence increases the angle of the wiper sweep, rubber hits screen surround etc....
HTH Keith
Post #935695 30th Dec 2021 9:20pm
dorsetsmith
517646 - Windscreen Wiper Motor Crank Gear - 115 Degrees (90/110 to 1A622423 2001)
DLW000020- Windscreen Wiper Motor Crank Gear - 140 Degrees From 2A622424
Post #935698 30th Dec 2021 10:11pm
excossack
Some good info there peoples and no, i am not made of sugar Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #935732 31st Dec 2021 10:18am
geobloke
Well at least we now know you must be made of puppy dogs tails and hence a boy 🤪
Post #935733 31st Dec 2021 10:22am
DSC-off
The easiest way to measure it with a protractor would be to extend the lines made by the extremities of the sweep and measure the angle between them. Perhaps use a rule and a non permanent marker to draw the lines on the glass.
Post #935742 31st Dec 2021 11:43am
excossack
Nice bit of art work done in MSPaint Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #935743 31st Dec 2021 11:49am
DSC-off
Artwork is Samsung Penup app, first try with it, but I think it will be handy. Thumbs Up
Post #935744 31st Dec 2021 11:57am
excossack
I followed the DSC-Off method and got a measure of 115 degree's or there abouts. There was some play in the grub screw that holds the splined adapter on, so tightened this up.
There is some play in the wheel box(not sure how much there should be) 1999 Defender TD5 110
Regards
John M0VAZ
Post #937923 16th Jan 2022 1:40pm
