![]() | Home > Technical > Limp mode help! |
Well oil in the intercooler is a fairly common thing, really depends on how much oil. It is also the reason many people fit a provent 200 in to their vehicles, to prevent oily gasses making it back in to the intake system.
Anyway... Induction noise. Perhaps a blown intercooler?! |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2472 ![]() ![]() |
That’s the “Air Charge Sensor” part number LR032216 on a 2.2 puma.
That’s what LR call it but in reality I think it’s an Air Charge Temperature Sensor. Whenever I have taken it out to check or give a clean with a maf cleaner spray it’s been dry, no oil. What DTC’s are showing Co1 Last edited by Ianh on 29th Dec 2021 7:34pm. Edited 1 time in total |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3748 ![]() ![]() ![]() |
The odd thing it that it is only making the whooshing sound in the cab when driving. If I’m in neutral it revs freely.
The hose from the turbo to intercooler wasn’t the tightest at the turbo end, got a good couple of turns on it.
Just twigged. When I changed the intercooler hoses, I didn’t do the short elbow as I just could work out how to do it!! Just felt round the bottom of it there is a bloody hole in it!!
Good you managed to find the culprit, someone else’s on here about a week ago had the same hose fail. If they replaced it they may have some tips on how they did it.
It’s the air inlet manifold hose that has split. Part 7. Looks like a pig to fit
