Home > Maintenance & Modifications > 1994 Defender 90 300 TDi Anti-freeze / Coolant type colour?
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
Evening all and seasons greetings!
OK, just flushed and changed my coolant.
Went to my local Landy specialist just to double check the correct type and he gave me 5 ltrs of 5 year life red which I've duely installed ...
However: Just noticed on a couple of Youtube video's on coolant replacement they've are using green and make no reference to RED??
I'm aware that one type is NOT good for the aluminium engines but which one is it please??
MTIA
John 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #935223 27th Dec 2021 12:45am
dorsetsmith
Post #935226 27th Dec 2021 1:38am
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
Please check the manual for your engine (is yours the 300tdi?).
I recently did mine and I used the blue, 2 year stuff which I think is ethylene glycol based. I believe this is for the 300tdi - but please check the manual as I don't have thar or my empty antifreeze container to hand!!
Try a search on here for 300tdi coolant as people far more knowledgeable than me can give better advice and reasoning.
Is yours OAT type, as I think that may be the wrong one - but please check. I know I would have preferred a 5 year life span due to my low mileage, but I had to go for the 2 year as that was the stuff specified for the 300tdi.
It will be an arse if the "specialist " has sold you the wrong type!
Post #935227 27th Dec 2021 6:43am
The NAPA Longlife Red is an OAT type solution but it's also Ethylene glycol based. It's billed as a universal coolant and the Opie website describes it as suitable for engines of ferrous or aluminium construction, so looks like your specialist is right:
https://www.opieoils.co.uk/p-215455-napa-l...o-use.aspx
https://www.napa-oil.co.uk/product/longlife-red/ Darren
Post #935245 27th Dec 2021 9:55am
Cubflyer
Thanks for your input Mick, yes I've a 1994 TDi300 and was slightly concerned because there are a lot of threads on various forums and some contradict each other.
Having not had this one long and my last was 11+ years ago I'm finding my way around again Smile
ATB
Post #935289 27th Dec 2021 3:54pm
Cubflyer
Thanks very much Darren - GREATLY appreciated.
I completely forgot about "Opie oils" website who I got my engine oil from and the "Napa-oil" website link is spot on, just downloaded the .PDF file for the Napa red and more than happy now Very Happy
ATB
Post #935291 27th Dec 2021 3:58pm
