Home > Maintenance & Modifications > Optimill and momo steering wheel fitted - thoughts
Page 2 of 2 <12
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
blackwolf wrote:
Yes, should have an O-ring.
A useful mod I did to mine is to drill a small hole radially through the cap just under the flange (between the lower face of the flange and the O-ring) to allow the air which gets trapped underneath when fitting the cap to escape, and similarly the vacuum created when removing the cap to be relieved. With some lube on the O-ring it becomes easy to fit or remove yet remains suitably snug. The hole is invisible when the cap is fitted.
Before I had this stroke of modest genius my cap would slowly eject itself a few mm after fitting due to the trapped air pressure and was impossible to keep fully inserted.
Just a quick comment on the above ... bought my Optimill system just over a month ago and the cap supplied was pre-drilled with a 1.5mm hole just under the flange so no issues with trapped air Smile
John 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #935221 27th Dec 2021 12:31am
Interesting, suggests that either great minds think alike or possibly the guys from Optimill have visited this forum (it's not the first time I've mentioned the hole on here).
I have a lot of respect for Optimill, they're a great bunch of people with superb customer service and take a great interest in the continual improvement of their products. It comes as no surprise to hear that the hole has appeared in the latest version.
Post #935244 27th Dec 2021 9:54am
Mattej
Slovenia 2007 Defender 110 Puma 2.4 CSW Blenheim Silver
I also have Momo Jet steering wheel in my Defender but I have one problem. Here in Slovenia we need a certificate that this steering wheel is compatible with Land Rover Defender. Did you get any certificate or any document with your steering wheel?
Post #935351 28th Dec 2021 9:59am
Page 2 of 2 <12
