![]() | Home > Td5 > HELP! Oil Filter Housing Haemorrhage |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 584 ![]() ![]() ![]() |
The housing for the oil filter has a pressed steel gasket.Did you change that?
Marc. |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 928 ![]() ![]() ![]() |
Yes I did, Marc.
Used a genuine LVH100230, which failed. I then tried another genuine one, which also failed in the same spot. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Mmmmm,is the engine pressurizing somehow?
Or,the oil level too high? Marc. |
Oil level is fine. Cold idle pressure was 3.5bar when I started it up earlier.
Just can’t understand it. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
I think the problem has been identified . . .
Cracked housing by the bolt. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
It's allways good when you find the cause of a problem.
![]() Well done. Marc. |
New housing on order, so fingers crossed that will sort it! Charlie
As expected.
![]() Click image to enlarge Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Well done....
![]() It's great when you find the root cause to a problem. Marc. |
Very satisfying to find, I must say! Charlie
