Home > Maintenance & Modifications > Oil Leak
MattyEssex
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Indus Silver
Oil Leak
Whilst not an unusual occurrence my 110 Puma seems to have a large oil leak.
Engine was pretty much rebuilt few months back having bought the car in Sheffield and then 30 mins later on A1 the engine went. It lived its life on IOM where it probably didn't go above 40-50mph then introduced to A1 and 70mph ....tap tap tap.. garage took a few months to carry out the work as fitted it in where they could to keep costs to the dealer down. Speaking with the mechanic they replaced the following;
New Front Cover
Cylinder Valves
Timing Chain
Pully Oil Seal
Oil Supply Valve Pump seal
Water Pump seal
All seemed fine however when sorting the front diff seal leak out noticed a lot of oil on n/s Engine as per picture.
Can anyone suggest where I can check to identify where this is leaking from?
Post #934774 23rd Dec 2021 9:35am
ickle
I can't comment on the leak, as others have said on various posts, clean it well and trace it upwards.
However I'd be dubious about anything the garage have told you, after a few months I'd have expected to see the front timing cover to be looking 'shiny' and new, plus the three stretch bolts that hold the bottom pulley on would look new as well, I can't actually see witness marks in the rust where they have been removed and refitted......
New valves and timing chain would indicate a broken / slipped chain so would need a complete kit with all guides and pulleys, plus I'd have thought it would have totally scrapped the engine.
Perhaps the proper mechanics on here who work on these and transits every day can comment?
Keith
Post #934781 23rd Dec 2021 10:32am
ickle
Sorry for the poor photo, I did the timing chain, front cover, pulley bolts etc in June this year, probably done 1,000 miles since and everything looks 'clean' if you can understand...
HTH Keith
Post #934811 23rd Dec 2021 1:28pm
