Home > Maintenance & Modifications > Alarm/Immobiliser Strangeness
A couple of weeks ago I noticed that the indicators had stopped flashing when unlocking (still do on locking). Some time later I also noticed that the red immobiliser light on the dash was sometimes staying on from start up. I discovered that if I turned the ignition off and on again then it would go out, though. It took me a while to realise that these two events were connected when one day the indicators did flash on unlock.
So, if I unlock and the indicators don't flash, then the immobiliser light stays on when starting. If I turn off and on again, it clears and stays off. This happens probably 9 our 10 times when unlocking.
It starts and runs as normal. I haven't yet changed the fob battery (although I have tried the spare fob with the same result) but I though the sign of a low battery was no indicators when unlocking or unlocking.
Any ideas, folks? Darren
Post #918020 20th Aug 2021 4:59pm
Ianh
I’m pretty sure that will be fob batteries, certainly the red immobiliser light staying on when engine is running is a sure sign fob batteries are low as that’s happened twice to me and new fob batts solved it straight away.
Post #918067 20th Aug 2021 11:16pm
Ah, ok. I'll give that a try, then. Thanks Ian. Darren
Post #918068 20th Aug 2021 11:19pm
Ianh
Best to get some quality varta ones from a reputable supplier as there are a lot of fakes out their and the cheaper batteries can cause issues.
Plus best to follow the fob battery change procedure and don’t touch the batteries with fingers as it shortens their life.
Procedure here 4th post down https://www.defender2.net/forum/topic37269...ob+battery
Post #918069 20th Aug 2021 11:29pm
HardCharger
That's the truck's way of telling you that you need to change out your FOB's battery.
Happened to me twice already. Thumbs Up
Post #918088 21st Aug 2021 9:17am
You were both right chaps, so thank you. I fitted a new battery and normal service has been resumed.
I'd half convinced myself that it couldn't be the battery, partly because I'd mis-remembered what the indicators do (or don't do) when it's low. A reminder to always check the simple stuff first Rolling Eyes Darren
Post #918124 21st Aug 2021 4:15pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Glad it was just that Smile From earlier discussions on here I summarised the various states of LED, indicators and alarm system: https://kraxlr.de/facts.html#led
Post #918171 22nd Aug 2021 10:04am
That's useful stuff - well done Thumbs Up Darren
Post #918174 22nd Aug 2021 10:45am
stephan123
Hi I am having the same issue with the immobiliser light staying on from startup. Could someone point me in the right direction for the fob battery replacement procedure? Many thanks
Post #934587 21st Dec 2021 8:33pm
stephan123
sorry just saw the link in the thread above
Post #934588 21st Dec 2021 8:36pm
