Home > In Car Electronics > Headlights go out....!
phillips321
2005 Defender 110 2.5 TD DCPU Belize Green
Hi all,
My main beam and dipped beam occasionally flicker out and don't immediately come back on. The side lights stay on however. I can hold back the indicator stalk to put my main beams whenever this happens but upon releasing the lights are sometimes still off.
I can't figure out whats causing this.
I have checked the dip/dim relay and that's missing and pins2+8 are bridged.
I've ordered a new indicator stalk and main master light switch but yet to fit as they sent the wrong parts Sad. If these don't work what else should i be checking? Where is the relay for these lights? I assume it's not a relay specific for these as the full beam flash still works...? I also assume it's not a grounding issue for the lights as the full beam flash wouldn't work. The sidelights are not affected however i think they might be linked to this problem?
So im thinking this has something to do with the switch or the side lights circuit? Does anyone have a full wiring diagram for this or any ideas?
Many thanks
Post #934542 21st Dec 2021 2:47pm
rallysteve
Sounds like a classic symptom of the headlight switch dying. Get it swapped over asap.
Cheers,
Post #934544 21st Dec 2021 3:10pm
Mo Murphy
I concur, dead headlamp switch, as the whole headlamp power goes through it, eventually melting the plastic that holds the contacts inside. Avoid this happening again by making or buying an additional lighting harness with relays.
50 Shades of Pennine Grey
Post #934547 21st Dec 2021 3:21pm
phillips321
As in all of the amps that go through the light are drawn through this switch and there's no relays???? That can't be right can it?
Post #934549 21st Dec 2021 3:27pm
Retroanaconda
It’s exactly right. There are relays in the system but they’re to do with ignition switching and dim/dip. The lamp current goes through the switch.
Post #934576 21st Dec 2021 7:02pm
Replace switch then fit this is your solution:
https://shop.landreiziger.nl/lichtversterk...elaar.html
(View in Google chrome and you can use auto language translate).
Alternatively, if you are able to and skilled enough you can make your own. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #934578 21st Dec 2021 7:21pm
phillips321
So switched changed and still have the same fault, any idea where the relay R123 is located in the vehicle (shown mid left of the below image) .
Many thanks
Post #934784 23rd Dec 2021 11:04am
dorsetsmith
passengers fuse box C0282
had same problem with 03 reg 90 with relay holder burnt and the blue wires burnt too ended up making two repair tells new female blade terminal
Post #934808 23rd Dec 2021 1:17pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
The relay you refer to (C0282) is in the passenger compartment fuse box. There is also a pink relay, the dim-dip relay, located behind the instrument pack. This went wrong on mine recently but that only affected dipped beam, not full beam as well.
MM
Post #934820 23rd Dec 2021 2:51pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I would do the wiring mod anyway before the switch does go, the loom is also available at Paddocks https://www.paddockspares.com/boomslang-pe...-loom.html 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #934847 23rd Dec 2021 6:39pm
