![]() | Home > Technical > Laying up a LR |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
off the ground leave them pumped up.
change the oils etc and make sure you have either drained the coolant or have enough protection in the coolant to cover the temp range. disconnect the battery, remove and leave on a trickle charge. |
Try and keep the tyres out of direct daylight too. Steve.
fresh oil, tape over the end of the exhaust, don't cover it unless well ventilated,spray silicone onto exposed rubber seals,if not on stands inflate tyres to 60 psi and leave a smear of polish on the paint 2.4 90 XS
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Best to keep anti freeze/coolant in rather than drain as most have anti-corrosive properties and could grease the exposed swivels
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
damp and mildew.
with quite large temp fluctuations make sure you keep it aired as well BM52 |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
24 months, hopefully you will get out earlier for good behaviour
you could sell it
Surrey Rover Member Since: 20 Dec 2010 Location: Surrey Posts: 360 ![]() |
Whaaat! No way, this one is a keeper Thanks for the advice chaps. Nick 2.2 110 Tipper |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2499 ![]() ![]() ![]() |
Actually, Defenders for export come with max tire pressure., i.e. 83 lbs. I would leave it on axle stands unless I`m sure somebody will drive it from time to time.
In the old times people poured a bit of castor oil thru spark plug holes and turn the engine a couple of revs to avoid rusting. Puma 110" SW ............................................................. Earth first. Other planets later |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
you could lend it to me and I'll keep it 'aired' for you.
save the miles on mine too ![]() |
