Home > Puma (Tdci) > Just appeared on the GTR: SSM40851
Page 2 of 2 <12
CapeLandy
South Africa
grease nipples
By the way - I found that the nipples at the diff end of the prop shafts are not reachable by the standard grease gun head. It's diameter will not fit between the knuckles no matter how you turn the UJ.
I bought one of those little hand held grease guns with the plunger where there is no head as such but just a cup end that you have to press hard up against the nipple.
Problem is you really need to press hard to force any grease in.
Not sure what type the workshop use to access them.
James Puma 110 - gone
Series III 1973 - going strong
Post #9337 2nd Apr 2009 1:16pm
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
If it's a LR dealer workshop they probably don't bother.
Post #9340 2nd Apr 2009 2:52pm
MK
No std gun will reach the bloody nipples. And it is right: dealers don`t bother at all. There are two ways a) reduce the diametre by grinding it or b) get a long sort of needle to plug in. With the former you will need help anyway. Puma 110" SW
Post #9341 2nd Apr 2009 3:56pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
How to grease your nipples without getting covered in the stuff, this is using a standard grease gun to!
1. Jack the front of vehicle (both wheels)
2. Put the low range lever in neutral
3. Turn the front prop to get the perfect grease gun angle
4. Grease all 3 nipples on the front prop
5. Drop the vehicle and do the same with the rear
Hope this helps, it has worked perfectly for me in the past! Thumbs Up
Post #9348 2nd Apr 2009 9:26pm
Bosun
Just got mine back from the dealer with a new front prop because of a missing grease nipple. Boy are the grease nipples difficult to get the gun on, I'm not sure they are oriented quite right. Does anyone know what type of fitting they are, screw-in or drive-in, I might give them a tweek myself. Also, the new prop doesn't have a nipple for the sliding joint, is it now greased for life, or something else LR have forgot to fit?
Bosun.
Post #9463 6th Apr 2009 7:36am
shorty
South Africa 2009 Defender 90 Puma 2.4 XS CSW Chawton White
Mine was vibrating terribly on the front. Just phoned the dealership and asked them to check and they can confirm that the front nipple is missing. Thanks Eduardo. They were a bit shocked that i had access to the info and led them in the right direction. Land Rover's don't leak oil, they simply mark their territory!
Post #9467 6th Apr 2009 10:15am
mhasting2004
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
No problems except step 4.... where's the 3rd nipple! Asked the dealer and they said that the new prop shafts dont have one for the splines! Can't see where one would be missing either.
Mark
Post #9600 10th Apr 2009 10:57am
mrwoo
Not sure! My 2007 model has 3 nipples per shaft, one for each UJ and one on the shaft for the sliding joint.
Thumbs Up
Mark
Post #9607 10th Apr 2009 4:20pm
Anvil
Italy 2008 Defender 90 Puma 2.4 CSW Tonga Green
Also here in the barbaric Italy some models seems to mount "greased to life" prop, so no nipple for the shaft ... not the black policeman Very Happy
We were wondering about the meaning of the word "life" in LR engineer's mind ... how long should it last ?
ohhh ... but this is a true philosophical question Very Happy
Post #9695 14th Apr 2009 9:52pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi guys, novice here, could you let me know which grease I should use on the propshafts and can I buy it locally from Halfords or the like.
ps how do I know when I have put the correct amount of grease in? Cogito ergo sum
Post #9712 15th Apr 2009 10:49am
Grockle
Paul, it will come out of the joints. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #9714 15th Apr 2009 11:12am
Paul55
Cheers Grockle. Thumbs Up Cogito ergo sum
Post #9715 15th Apr 2009 11:34am
Anvil
Hi Paul ... the suggested grease for props and joints is a Lithium based grade NLGI 2 grease.
It would be better if you find the EP (Extreme Pressure) one
I usually use John Deere Premium Plus ... but only because a friend of mine works for the Deer Very Happy and we usually exchange a pint for a pint Laughing
Post #9746 15th Apr 2009 11:24pm
Page 2 of 2 <12
