Home > Td5 > missfiring woes
alexatnd
missfiring woes
Hi ,
Need some help if possible.
Wife was out driving 110 TD5 when sudden loss of power and lots of grey smoke. Managed to limp home and get onto drive .
At this point no missfire, engine seemed to run o.k. and rev fine just what I asume was unburnt diesel ( not a lot though)
Conected the lync diagnostic and there was an error associated with injector 5. and a few relating to things not actually present on the truck.
Cleared the codes and started again ... again no missfiring and some grey smoke.
This morning went out started again. this time, clouds of grey smoke and definite missfire.
Checked fault codes ... none
Fairly good at diagnosing petrol engine issues, but diesel is a completely different world
where do i start to figure out which cylinder is at fault?
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #933393 13th Dec 2021 12:56pm
landy andy
I’d start with new air and fuel filters. How old is the fuel filter?
Any odd fuel pump noise recently?
When did it last have an injector loom? Have you checked red plug?
Post #933394 13th Dec 2021 12:59pm
alexatnd
o.k
Had an issue with bad starting a couple of months ago
so
changed fuel pressure regulator and checked pressure, 4 bar
new glow plugs
new fuel filter housing
new fuel filter
new injector harness (land rover)
red plug clean no oil
At mot, told local garage to change injector seals .. and all of the bolts holding what i'd call the rocker shaft sheared. Had a 10p TD5 in the garage so they took the head of that and put that on, with its injectors, dont know if they changed the injector harness at that point or used the one in that was in there. They were a bit timid about changing the seals on that head (understandably)
Air filter was changed a month ago
New fuel filter few 100 miles ago,
fuel pump sounds good
did change injector loom farily recently Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #933396 13th Dec 2021 1:10pm
landy andy
If they used the other set of injectors did they code them to your current ecu?
Post #933404 13th Dec 2021 1:44pm
alexatnd
yes they did,
The missifre was a red herring. After running for a bit it went away. However, checked the oil level and was damn near empty. Since 2012 this engine has hardly used any oil and just had to put 5 ltrs in it to get it to the max level.
Still loads of white smoke though and no erro codes.
Thoinking thst the turbo might have gone south. revving ther engine and squeezing an intercooler hose produced hardly any push back from the squeeze Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #933431 13th Dec 2021 4:15pm
alexatnd
could be turbo filling up intercooler with oil Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #933434 13th Dec 2021 4:24pm
landy andy
Sounds like the turbo is burning oil. Take the pipes off it and take a look.
Post #933465 13th Dec 2021 7:47pm
