![]() | Home > Maintenance & Modifications > Best quality springs |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6025 ![]() ![]() |
Why do you want to change your springs if you want a standard setup, which I assume you currently already have?
RFOZ Member Since: 29 Sep 2021 Location: Cambridgeshire Posts: 4 ![]() ![]() |
Corrosion.
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677 ![]() ![]() |
Honestly, try the alive comfort springs… much better ride, I’ve towed 3 ton + a few times now and no drama.
I have had a chat with Alive regarding their comfort springs as they were my number one choice. They did warn me against them for towing heavy loads so I’ve started looking at standard springs again. I’d be quite happy with Eibach quality but prefer standard spring rates. Yes maybe not quite as compliant as Alive comfort springs and Fox 2.0 shocks but more “utility” when required.
Does anyone sell Eibach springs in standard spring rates? |
I initially was the one who discovered the issue with the alive springs towing heavy, but since then made some modifications with the longer spring and tow a 2.6ton boat & tri axle ifor around without issue…
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2407 ![]() ![]() ![]() |
Every spring you put under your Defender will rust unfortunately, they're in just about the worst place. Standard genuine shocks will probably do a better job of day to day work than fancy Fox shocks.
Just my twopennysworth Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
There’s no comparison between standard lr shocks and fox’s.
It’s night and day difference |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3781 ![]() ![]() ![]() |
+1 For the alive/fox set up.
kaney Member Since: 01 Oct 2018 Location: Bolton Posts: 232 ![]() ![]() ![]() |
Speak with Gywn Lewis 4x4
https://gwynlewis4x4.co.uk/contact/ He will give you good advice |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Fox/Alive(eibach). Go from a crashy 90 to actually feeling damping work, no brainer. QRZ 2e0vpf
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 707 ![]() ![]() ![]() |
Me too for Alive comfort springs and fox shocks .. been excellent on my 110
Alive springs certainly seem well loved!
...Do they have any competition at all? |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
Id just get some standard OEM LR ones theres not much wrong with them and you see them on ebay all the time as take off items from newish defenders when people are upgrading for not much £.
Gravygraham Member Since: 15 Mar 2017 Location: East Kent Posts: 187 ![]() ![]() ![]() |
I too am considering fitting Fox 2.0 shocks with Alive Comfort springs on one of my 90’s. My only trouble is deciding whether to opt for standard height or 1” lower. I presume there’s a touch less roll on the lower ones but seeing as my Stirling Moss days are behind me I’m struggling to make a choice. Anyone got any comments on either setup? Lucky custodian of several Landies
