Home > Wheels & Tyres > Wheel adaptor |
Solis Member Since: 01 Dec 2021 Location: Nicosia Posts: 7 |
Hello guys how easy is it to fit Wheel Adaptor Kit 5/165 to 5/120 on a td5 defender
5th Dec 2021 8:48pm |
They just bolt on. This is on a Sankey trailer rather than a Defender but the principle and the bolts are all the same:
Click image to enlarge The only thing I'd recommend is to use capless alloy wheel nuts rather than the standard ones. The tolerance of the holes in the adapter are very tight and the caps on the standard nuts have a habit of swelling, making them difficult to fit. Capless nuts were standard on the earlier Discoverys but are also readily available as an aftermarket item. Oh, and depending on the make of the adapters and what wheels you plan to fit, you may also need a spigot adaptor kit to ensure hub centric fitting of your chosen wheel. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
6th Dec 2021 7:47am |
