Home > 130 > Joined the club
Page 2 of 2 <12
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
No worries, I’ve found a place that does camper conversions in salisbury and a little bird tells me they might do pop tops, I’ll find out in the next couple of days…
Alex 98 300 tdi 90 project
88 200tdi project soft top
96 disco 1 jap import
79 911 sc
08 130 double cab utility
Post #929120 8th Nov 2021 8:06pm
110defender
framing almost finished, cladding underway
A bit more progress,
Framing almost complete, stainless underfloor fitted and a good chunk of the cladding on.
Hoping to get the outer buttoned up before the weather really turns.
Post #931688 29th Nov 2021 1:54pm
Zimblewinder
Australia 2000 Defender 130 2.5 TD HCPU Chawton White
nice rig. Never mind the dimples, they only add character and save you from the big cringe the first time you bump a tree branch. Point of caution having driven bigger trucks, I think your rear wheel to top corner distance is likely to cause you grief when going over humps or passing under trees etc. Your proposed roofline will be hard to judge from the cab as its not natural to the vehicle and also will shift significantly with any incline/decline. Personal opinion but id go a full roof level pop top if I had my turn again. looks like you have the skills to do the job yourself too. Looking forward to seeing you progress. All the best
Dale
Post #932379 4th Dec 2021 9:12am
110defender
Thanks Dale,
Im hoping the 'dimples' make it less nickable.
We really struggled to pick a height that suited our needs as well as keeping a relatively low profile. As with everything its all about compromises, not planning any serious off roading so fingers crossed it doesn't become an issue.
Pop top is full roof and plans are progressing, everything just takes so much longer than i thought.
Thanks
Scott
Post #932599 6th Dec 2021 11:32am
Ratty43
Great looking 130! I'm (very slowly) in the progress of converting my 130 into a pop top camper. Bit different as mine is a truck cab with a long quadtech on the back. I've bought a T25 canvas and some scissor hinges and intend to make a fame to fit them. Depends on how much width you want though, mine will only be in the centre which gives about a double bed width. I suspect I'll quite often crack my head on the step in width when the bed isn't in place.
Post #932668 6th Dec 2021 9:23pm
Willcalvert
2015 Defender 130 Puma 2.4 HCPU Alaska White
I was thinking of a custom back for my 130 chassis, and wondered if anyone could recommend an off the shelf unit.
New to this site, but need to make some progress as this project has stalled in 2021, and I would like some progress in 2022.
I have bought an ex SSE maintenance truck, very clean and well worth doing properly.
Thank you
Post #933741 15th Dec 2021 9:41pm
Ratty43
That's very similar to mine. My plan is to use the box body with a T25 canvas on a poptop.
Post #933742 15th Dec 2021 9:44pm
Willcalvert
That would give very little headroom I think.
Post #933743 15th Dec 2021 9:52pm
Ratty43
It will give about 7 feet at the high end diminishing to 5 odd at the far end where I plan to have storage and the water tank together with batteries. Like all these things it's a compromise, live with reduced headroom whilst having decent clearance.
Post #933744 15th Dec 2021 9:54pm
Willcalvert
I was hoping to achieve something like this.
Post #933745 15th Dec 2021 9:55pm
Ratty43
Looks impressive, I'll look forward to reading your log!
Post #933748 15th Dec 2021 9:56pm
Jabberwocky
Luxembourg
Thank you
Check out globecamper, they aren’t cheap though.
Post #934482 20th Dec 2021 11:29pm
Page 2 of 2 <12
