![]() | Home > Puma (Tdci) > Best 2-stroke? |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Okay - I'm taking the plunge and experimenting with 2-stroke in the diesel for my Puma this winter. Have read about this in other threads but get mixed messages. So -
Can anyone recommend type/manufacturer for the oil? Also interested in this Forte stuff - any advice on that? Cheers, Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
| pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568
I gave the 2 stoke a go about a week back. To be honest I cannot comment on power or economy, however I have noticed that the engine sounds quieter and smoother. I used cheap mineral based oil, low ash which will burn completely away. Doubt that @ 300mills in 70 litres will cause any problems if it reduces friction in the fuel system it may actually reduce heat. If it increases the cetane valve of the fuel it has to be a good thing.Maybe someone with more knoledge could comment.
| willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789
So 230/1 mix ratio, is the this the common ratio? Original Member Pie n Pea Club.
110 HCPU Tipper |
| Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166
I do 200/1 and use Yamaha outboard oil on both my TD5 and Puma. Yes both seem to run better and make less noise. No smoke and smell lots better. I would not run either without again.
Allan |
I would like to add that I also have no smoke before and after ( opps
| XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632
Castrol Actevo FC
| rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297
yep XS pete thats what I'm using at the moment cos I got 5 bottles for € 5 each from a local farmer's co op and that's cheap !
| pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
i use it, may be placebo but is 'does' sound quiter, i dont really monitor mpg as it would just annoy me!
Pom |
| The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459
I have got to pop over to Halfords latter will the Halfords Low ash, mineral garden machinery 2 stroke do or should I go for the more expensive products and if so which one?
http://www.halfords.com/webapp/wcs/stores/...nce%7C%7C0 |
What do FB and FC stand for? I can only get Castrol Act evo 2T here (2T = 2-Takt = 2-stroke) They are all mineral-based >>>>>>> Duh, sorry, just read it exceeds Jaso FC (guess that's the "FC" then) Cheers, Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Ze defender maybe do a normal google search to find out the differences between the two as there are reams of techno stuff on it.
The way I understand it is that FB = mineral based low ash. FC= semi synthetic and even lower ash than FB. The FC however may not burn as fully as the FB being semi synth although its recommended for DPF engines due to less ash residue which to me translates as swings and roundabouts so I buy whatever is the cheapest ! |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
There are pages of info on this on here,
http://www.defender2.net/forum/topic1708.html Personally I use the cheapest JASO FB mineral oil that I can get a deal on. I prefer the Motul from OPIE oils and it is a good price http://www.opieoils.co.uk/p-928-motul-100-...gines.aspx Brian. |
Okay - have finally settled on FB not FC (to protect my cat).
Motul 100 Motomix 2T was my choice (I like Motul products, as you may have gathered) I'll use 250 ml per 65 l fill-up (about 1:250). Go-on, just tell me I'm wrong, I dare you! Thanks to all Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
... but hang on - I've got Castrol Act evo 2T in my garage and it's also supposed to be "mineral" and its FC???
May have just needlessly bought the Motul... But shout it at them in German because life is also terrifying and confusing... |
| All times are GMT |
