Home > For Sale & Wanted > [Wanted] LT230 1.2 Ratio disco transfer box wanted
ezzysi
2000 Defender 90 Td5 HT Belize Green
Looking for a 1.2 lt230 to drop the gearing on my defender, ideally with difflock and around East Midlands area.
Simon
Post #931630 29th Nov 2021 12:22am
If your Defender is the TD5 in your avatar, fitting a 1.2 box will raise, rather than drop, the gearing, by about 15%.
Post #931649 29th Nov 2021 9:10am
ezzysi
Probably didn’t phrase that correctly then. I’m looking to lower the engine Revs as it’s mostly used on road.
Post #931690 29th Nov 2021 2:06pm
That makes sense! Ideally you need a Puma transfer box but you could use a Disco2 box and swap the rear output stage from your existing one (for the Speedo drive) and if need be swap the difflock parts as well. Puma would be easier if you can find one.
Post #931700 29th Nov 2021 3:10pm
Dinnu
Disco1s also had 1.2 ratio. However still half way into the 300tdi builds, the input gear was not yet drilled. So if you find a good earlier TC that does not have the drilled input gear, factor in the cost to replace the input gear (start at £55 from Ashcroft), plus perhaps a new set of bearings, £26, and shims and labour.
Personally I think the older boxes with larger gear teeth are stronger than the later Q boxes, but no data to back up this. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #931707 29th Nov 2021 3:46pm
