![]() | Home > Td5 > Rear wiper not working |
Have you checked the contacts are clean, especially the earth and that there is 12v at the wiper motor. If that lot is A-OK then it is time to open the motor up and have a look at what is going on inside. Could be just that the motor's brushes are grimy or the spindle is bunged up with rust.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6051 ![]() ![]() |
Check the arm isn’t against the spare wheel. Check the relay under the dash, also check the earth to the door, as you know you have a live supply. If me I’d stick 12V direct to the motor and see what happens. That way you know if it is supply, or motor.
![]() Click image to enlarge ![]() Click image to enlarge |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 1007 ![]() ![]() |
The motor was duff on mine when I had the same problem. One of the magnets had come away and water had played a bit of havoc in there as well
Had to get a new one in the end. |
nobbyclark Member Since: 19 Jan 2011 Location: Cumbria Posts: 56 ![]() ![]() ![]() |
Thanks for all the replies; yet another project for the weekend.
Does anyone know if a non-functioning rear wiper is an MOT fail? I've looked at the Government MOT site and it mentions forward facing windscreen and wipers but nothing about the rear. Various other links suggest it is OK but I obviously want it fixed either way. |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243 ![]() ![]() ![]() |
Worth a check of the wires in the corrugated rubber duct which runs between the body and the rear door. The cables often break due to fatigue where they bend much like the side doors.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Thanks for that; someone responded in the central locking thread about a similar problem so will definitely check.
Piggle Member Since: 24 May 2015 Location: Surrey Posts: 83 ![]() ![]() |
A non working rear wiper is not an MOT fail.
Thanks for confirming; fingers crossed for Monday!
