Home > Td5 > Fuel pipe push on connectors
excossack
As you look at the fuel filter housing, the right hand side front connector does not seem to want to stay clicked in place (got disturbed when the garage did some welding in the area and had to disconnect the fuel filter housing) I noticed a slight leak from the connector over the weekend. For now I have tried to push it back into place but not convinced thats fully home/clipped into place.
Is it possible to buy new push on connectors? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #930833 23rd Nov 2021 4:08pm
geobloke
Hi John. I believe these are what you are looking for https://www.ebay.co.uk/itm/384105940412?ch...vsQAvD_BwE
Had them bookmarked for just such an occurrence Smile
Post #930838 23rd Nov 2021 4:54pm
excossack
Cheers Geobloke
A UK seller
https://www.ebay.co.uk/itm/164550246853?ha...SwsR5ffI4M
Does the existing fuel hose just pull off the barbs or am I setting myself up for a fight? 1999 Defender TD5 110
Regards
John M0VAZ
Post #930841 23rd Nov 2021 5:00pm
geobloke
I am afraid I have not done this before John, but i would suspect that some gentle heat will soften the plastic enough to remove the old connector and emplace the new one. I would however add either a little sealant and/or a sprung clip like these
https://www.ebay.co.uk/itm/303530001800
Post #930842 23rd Nov 2021 5:08pm
excossack
Some gentle heat might have to be the way forward. Or I take it back the garage and say fix this, it was fine before the work.!!
I will see how the connector goes over the next couple of days, before I start taking it apart. 1999 Defender TD5 110
Regards
John M0VAZ
Post #930844 23rd Nov 2021 5:10pm
rallysteve
Cant think off the top of my head which pipe that union is. I would probably replace the pipe though if I were you. To get a good seal with those barbed connections you need a fresh bit of pipe which will mean cutting the end off the current one and heating it up with a hot air gun. I fitted some new ends at the pump end on mine and wasnt easy.
I have got the old long fuel lines off my 110 TD5 if they are any use to you. You could possibly salvage the latching bit of the union off them to fix yours?
Cheers,
Post #930845 23rd Nov 2021 5:23pm
excossack
Hi Steve
Good point on the pipe. If you have those pipes I could be interested ? PM details and we can discuss.
cheers 1999 Defender TD5 110
Regards
John M0VAZ
Post #930848 23rd Nov 2021 5:48pm
dorsetsmith
make shore you get right fitting to fit fuel filter fitting 7.89 to fit TD5
Post #930866 23rd Nov 2021 7:15pm
