Home > Td5 > What is this noise?
seventhtiger
Canada
What is this noise?
Hi - can anyone tell me what the noise is?
Around:10 of the video.
It occurs mostly when gearing down, or when releasing the clutch while the revs are higher. Doesn't do it all the time, but have also noticed the noise then releasing the clutch in first gear...
Also see around the :20 mark - I believe this is a exhaust manifold screech - yes?
Post #920784 10th Sep 2021 4:44am
Dinnu
This is a Td5 engine?
Sounds like a dry bearing, possibly the alternator or vacuum pump (they are are coupled to each other). Wonder if the screeching sound at 0:18 is the result of the first sound at 0:10? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #920789 10th Sep 2021 6:43am
seventhtiger
Canada
I am pretty sure the screeching at the end of the video is a leaky exhaust manifold.
The sound, by my estimation is coming from the transmission. But could be wrong. It's not there all the time. Mainly when gearing down.
Yes, TD5 engine.
Post #920791 10th Sep 2021 6:57am
landy andy
The screech at the latter end of your vid is warped exhaust manifold.
Look for black soot marks at both ends, and try the nuts on the manifold, I bet they are loose, snap off, or are possibly missing.
Post #920795 10th Sep 2021 7:59am
The noise around 10 seconds in sounds very like the noise that my Disco2 started making, intermittently at first then all the time. Quite alarming, and it went away when I fitted a new (pre-owned) gearbox and transfer box, sadly for the noise to be replaced by a substantial oil leak from - I think - the t-box which I still need to sort out.
I attributed the to a failed layshaft bearing in the R380, but have subsequently found when stripping the transfer box to overhaul and refit to sort out the leak mentioned above that the intermediate shaft bearings in the transfer box were just starting to fail, and one had clearly just started spinning on the shaft. It is possible that this may have been the source of the noise, but I would be surprised (it sounded worse). I have not stripped the R380 at this time, though it is on the "to do" list simply to see if I can find the source of the coffee-grinder" noise.
I am assuming, by the way, that the clutch was in at the time of the noise at the 10 second mark. If the clutch was out, it could be the spigot or release bearings.
Post #920805 10th Sep 2021 8:40am
seventhtiger
Canada
The noise is as the clutch comes out (ie peddle coming up)
Bearing?
Post #920862 10th Sep 2021 2:52pm
Dinnu
Had that noise when letting off the clutch and engine rpm is a bit high, and not only on Defenders. I attributed the noise to vibration on the friction plate as it is being clamped between the pressure plate and the flywheel.
Do you know if you still have the dual mass flywheel? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #920865 10th Sep 2021 3:02pm
seventhtiger
Canada
I don't know. But I am assuming that this truck has not been touched since built.
So if it this - new flywheel - and might as well replace the clutch/friction plate/etc...while at it?
Post #920885 10th Sep 2021 5:34pm
Bearing?
Ok, you mean the clutch is coming in not out. An "out" clutch is disengaged (pedal on floor), an "in" clutch is engaged (foot off pedal). If you are operating the clutch at the time of the noise it may be a clutch noise or a gearbox bearing-related noise.
Post #920891 10th Sep 2021 6:03pm
seventhtiger
Canada
Right you are correct (in-out-on-off lol)
Yes, the noise happens after the shift as I am bringing the peddle back up. Bringing the clutch "in"
Post #920896 10th Sep 2021 6:12pm
seventhtiger
Canada
Yes - firewall end has them missing. Studs are still there. I take it I just can't "put new bolts on". They whole thing needs to come off and be flattened/machined.
Post #920905 10th Sep 2021 6:26pm
Peppercorn
Australia
Mate, that bearing noise around the 10 sec mark is the throw out bearing on the clutch fork imo
I don't have a Defender and I don't even know how the clutches are designed on them but I'm an old mechanic, and as soon as I heard it, I knew. Well, I'd bet most of my old tools on it.
If it only makes that noise on change downs at high speed and not while your idling or taking off in 1st gear you may have a pretty used input bearing as well? It could also be the spiggot bearing being dry but I reckon by the sound of it, it sounds like the throw out bearing.
Don't take my word for it though because you really need to be there to hear it and drive it. Good luck though.
Post #930797 23rd Nov 2021 12:59pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Clutch release bearing is failing…. Mine has been doing this for several years but only at low speeds. I have put maybe 60,000 kms on it with it making that noise. It has not become worse which is why I have done nothing about it. If it get worse time to do the clutch Thumbs Up
Good luck. 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #930831 23rd Nov 2021 4:00pm
