[SOLD] Custom h/duty Pendle towbar mount bike rack
Price reduced to £159 to members of the forum :
I've listed this on eBay, but thought I would also put it on here as well because I know there are some keen cyclists amongst us!
It is a heavy duty bike rack that I had custom built by Pendle to take two eBikes and a regular bike.
It is based around their heavy duty bike carrier which they no longer sell and uses thicker walled tube and bigger box sections for the wheel supports.
I had it fitted to my Jeep which has a tailgate mounted spare wheel, so I am sure it will also work OK on a Defender. The rack is fully adjustable so the bike positions can be moved forwards or backwards along the tubes to suit.
It has an integrated lighting set and 7 pin electrics.
Comes complete with the flange towbar mounting plate and all the bike securing straps.
We only used it three or four times and it has been stored undercover when not in use, so in excellent condition.
If you are thinking about using it on a normal car, you will need to make sure the towbar and vehicle are rated at 80Kg minimum nose weight if you plan to load the rack with two eBikes and a regular bike. Not an issue if using on a Defender
It is built like a tank and should give years of service.
Originally cost £314. Asking £159.
Collection only from Skipton, North Yorkshire, but I'll happily help to fit the mounting plate to your flange type tow bracket so you can drive away with the rack fitted and I can supply cups of tea and coffee.
If it sells through the forum, then I will make a donation to Martin to support the site.
30th Oct 2021 11:01am
lohr500
Price reduced to £170.
5th Nov 2021 9:01am
lohr500
Reduced further to £159 for Def2 members. It's a bargain at this price for such a substantially built bike carrier.
22nd Nov 2021 3:51pm
lohr500
Sold and collected Plus donation sent to Martin to support the site.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
