Home > Maintenance & Modifications > 2013 Defender 110 ACC Fuse Slot & Headliner Removal
DocJon1
Kenya 2013 Defender 110 Puma 2.2 CSW Nato Green
Hello from Kenya!
I am installing a Discovery H612T Mirror Mounted Dash Camera. I have come across 4 problems / Questions for which I need assistance:
1) Is there an ACC Fuse Slot in the Fuse Box, and if so, which Fuse Box (Under seat or under dash)? Or, can the "ACC Fuse Slot" be any switched fuse that is powered with starting the car?
2) is there a good way to remove the pins holding up the Headliner, in case I need to run the cable that way to the back?
3) The mirror sags due to the small weight put on the Standard Mirror when I attach the device to the mirror. Is this normal? Also, any recommendations to give the micro more strength when attaching the device, so that the mirror does not sag?
4) Lastly, where can I get this document, "Headliner Rear Trim Panel - 90/110 (501-05 Interior Trim and Ornamentation, Removal and Installation)?"
Thanks, or Asante Sana in Swahili!
Jon Jesus is King!
Current: 2013 Defender 110
Past: 2000 Ford F-350 V-10 Crew Cab, 1989 Ford Ranger V-6, 1980 Ford Ranger V-4, and 1994 Ford Mustang (Okay, 2 Buick LeSabres!)
Post #930621 21st Nov 2021 8:03pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Don’t know about 1-3 but 4 I would say is from the workshop manual, if you search for a electronic workshop manual on here you should get a link you can use Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #930639 21st Nov 2021 10:00pm
Ianh
Post #930646 21st Nov 2021 10:45pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Hi,
1) In the above wiring diagrams ACC(essory) is called AUX(iliary). It's the ignition key's first position before ignition is switched on. Blower will work in that position, e.g., so you could tap it's fuse, which is F28 (30 Amps) under the dash. Other AUX-switched fuses are F26 (20A, cigar lighter) and F27 (5A, radio).
2) yes: focus on not damaging the headliner and don't mind about destroying the pins Laughing
Post #930783 23rd Nov 2021 11:29am
2) The headlining pins (known as fir trees) can be easily removed with a trim removal tool like this:
It helps to protect the headlining with a piece of thin ply or hardboard under the heel of the tool to avoid leaving leaving any marks. Darren
Post #930787 23rd Nov 2021 11:37am
