Home > In Car Electronics > Quick question about led bulbs for interior courtesy lights.
Gravygraham
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Several years back I replaced the factory fitted bulbs with leds in my 2015 90, it made a great improvement. Said led bulbs have now both died but I can’t remember what spec they are - anybody able to give me a clue? Lucky custodian of several Landies
Post #929727 14th Nov 2021 7:38pm
ChrisCSL
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
These are the LED interior bulbs I use in my puma. Nice light. Kit includes two bulbs.
https://houseofurban.co.uk/collections/lan...t-bulb-kit
Chris
Post #929823 15th Nov 2021 2:15pm
camelman
Or you can go the cheapo ebay route.
I got a pair for £3 and they work fine Wink
just search C5W LED
Post #929830 15th Nov 2021 2:39pm
Matt110
Any idea what length you ordered camelman and whether they are then dimmable as per the theatre dimming on later vehicles?
I guess CANbus compatible should help, but not sure there....
Post #929846 15th Nov 2021 4:50pm
Ianh
Food for thought if you have a Puma from 2012.
From remotekey on failures of the ALM ECU.
“A problem with Defender 2012 onwards with the black unit fitted is they don’t function with LED interior lighting, we have had problems with the interior light circuit failing when LED’s are used”
By which they mean the interior light circuit in the ALM ECU failed due to the use of LED’s !
Last paragraph before the pics at the bottom of the page https://remotekey.co.uk/land-rover-keys-re...larm-ecus/
Post #929907 15th Nov 2021 10:56pm
lakelander
United Kingdom 2013 Defender 90 Puma 2.2 CSW Orkney Grey
This is new news for me, and is potentially alarming ! ( sorry! )
My Puma is a Dec 2012 build ( reg march 2013 ). It is still on its original battery and battery , alarm, immobilized and fobs are all performing well. It has led bulbs in the interior lights which also work fine ( although the front interior does flicker when rear door is open ? Bad earth? )
Having read the link to remotekey.com I will need to check out the colour and part number of my alarm control box.
Had anybody experienced these problems of the alarm control box failing when the vehicle battery is old and dying?
It will be cheaper and less problematic to change the battery than change the alarm control box
Post #929939 16th Nov 2021 10:34am
camelman
Can't remember off the top of my head, I just bought the same length as currently in there.
They do dim after closing the doors (in my TD5), I've got the MUDSTUFF complete replacement units in the Puma
Post #929948 16th Nov 2021 11:50am
Ianh
Re ALM ECU failing due to low battery causing brownout, unfortunately YES . See this topic and my posts https://www.defender2.net/forum/topic80048.html
Yours will likely be an ALM ECU (black) and be a CH serial number. So keep the battery well charged.
Post #929958 16th Nov 2021 1:29pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Are you sure? Switches go to the ALM, ALM controls both lamp's earths (in the auto/dim position) in parallel. Also all door switches but the driver's door are wired in parallel and the ALM can't tell which one is which.
So, if only one lamp flickers, something's wrong with the lamp, but it should flicker if any of the doors is open. On the other hand, if only one door causes a flickering lamp, the door switch may be bad, but then both lamps should flicker.
Post #930024 16th Nov 2021 8:59pm
ChrisCSL
Cheapo LED lights are known to cause issues. I can't comment on the alarm/interior light issue. It's not uncommon that cheap headlights ruin radio reception and can cause other issues so why not.
Best to by from reputable LR suppliers and treat eBay with caution.
Post #930083 17th Nov 2021 12:56pm
ChrisCSL
More info which might be interesting:
https://www.defender2.net/forum/topic33693...ight+issue
Post #930084 17th Nov 2021 1:04pm
lakelander
Yours will likely
Thanks for advice
Silly question I know - but where is the Alarm ECU located? Can't find it !!
Post #930233 18th Nov 2021 3:35pm
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
I have used these
https://www.ebay.co.uk/itm/2x-PURE-WHITE-L...635-2958-0
No problems, no flicker just clean white light.
Jim
Post #930235 18th Nov 2021 3:46pm
Ianh
lakelander wrote:
Thanks for advice
To check remove drivers footwell speaker and look upwards under your dash with your head just above the peddles. If the unit is black it’s the ALM not a 10as which is green . If serial number beginning with CH it’s first gen ALM ECU, if DH it's second gen ALM ECU
Post #930305 18th Nov 2021 11:51pm
lakelander
Thanks
Post #930327 19th Nov 2021 11:11am
