Home > Puma (Tdci) > 2.4 2008 Whistling / blowing issue
Trendkill110
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Barolo Black
Hello folks.
2008 2.4 110 and an issue has arisen.
Figured I'd bang a couple of quick videos on here.
First Puma I've owned so worth an ask as possibly a common fault???
Comments welcomed.
Thanks in advance 👍🏻
https://youtube.com/shorts/uHowSgJtwRQ?feature=share
https://youtube.com/shorts/Sfe5KhUM8Kk?feature=share
Post #929504 12th Nov 2021 4:57pm
landy andy
Exhaust manifold to turbo gasket. They distort, as does the turbo body. Remove the heat shield and look for soot /heat marks.
Post #929550 12th Nov 2021 10:33pm
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
As already said, most likely to be the manifold to turbo gasket. Take the shield off and have a look for any black soot. Also check the manifold itself as I had a crack in mine with the same results.
If it is the gasket either replace and hope for the best, or take off the turbo and get it skimmed and replace gasket .. or replace the gasket with a Nakatenga one that is designed to deal with any imperfections
https://www.4x4overlander.com/product/naka...-gasket-2/
Post #929584 13th Nov 2021 9:39am
Trendkill110
Thanks for that guys!
Overlander 4x4 are only 30 minutes drive away from me so heading over there this morning to collect the gasket and stud set.
Any ideas of torque settings for the stubs / nuts?
Thanks again 👍🏻
Post #929786 15th Nov 2021 9:53am
carrotbay
Hi
23Nm for the turbo to manifold
45Nm for the turbo to exhaust down pipe/cat
Post #929810 15th Nov 2021 12:47pm
Trendkill110
Gasket and nuts / studs collected.
Heat shield removed.
Already looks to have the uprated / thicker gasket fitted.
I believe that looks like a cracked manifold!
Where can I source a replacement that's been skimmed so I know it's decent and hopefully only have to do this once?
Thanks again Big Cry
Post #929815 15th Nov 2021 1:26pm
landy andy
Two options. Fit new kit and see how it goes. Or remove turbo, and exhaust manifold and get the machined flat. Check for cracks when doing any of it.
Post #929819 15th Nov 2021 2:04pm
Trendkill110
Land Andy -
I think I've found a crack as pictured.
Does anyone know if the exhaust manifold is the same as fitted to transits?
Thanks again 👍🏻
Post #929822 15th Nov 2021 2:14pm
carrotbay
I bought a used transit one off eBay, took off the turbo and got them both machined flat and refitted with a standard gasket. Prior to that I’d been through several gaskets and it was a PITA despite getting pretty quick at changing them.
No issues yet .. 3 years since doing it properly.
Post #929826 15th Nov 2021 2:17pm
landy andy
Trendkill110 wrote:
Land Andy -
Thanks again 👍🏻
Yes. I noticed that, and part of the reason I made the comment. Wasn’t sure if was a casting line though. Also the casting of the turbo isn’t great as I’ve previously found out.
Post #929828 15th Nov 2021 2:24pm
dorsetsmith
fords part number 6C1Q-9430 for exhaust manifold on 2.4 engine mk7 2006 - 2014 transit
Post #929836 15th Nov 2021 3:03pm
Trendkill110
Has anyone had experience with these?
Land Rover are coming in at £330+VAT
Ford Parts UK are coming in at £445+VAT
Post #930020 16th Nov 2021 8:08pm
Ianh
Blimey... Ford more expensive than land rover ! the world has gone Topsy-Turvy
Post #930033 16th Nov 2021 9:43pm
dorsetsmith
Land Rover Logo
SKULR004489
Genuine OEM LR004489 - LR Manifold - Exhaust (LR004489) part for Defender 2007 >. Authentic LR Part.
£758.48 + P&P
I say that price is cheep for JLR genuine Manifold - Exhaust
Post #930035 16th Nov 2021 9:49pm
landy andy
Not wishing to pee on your parade but check
Post #930036 16th Nov 2021 9:52pm
