![]() | Home > Puma (Tdci) > Rear seat rake adjustment |
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 244 ![]() ![]() |
Bit of an old thread, hopefully enough time has elapsed for someone to have figured how to make the drop down seat backs less upright… 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
skidrov Member Since: 06 Oct 2013 Location: Melbourne Posts: 56 ![]() ![]() ![]() |
Far Corners have a product:
https://farcorners.co.uk/product/far-defen...at-risers/ ...but you may find the timeliness of response variable. I have these, they fit/work well, but it took a while to complete the transaction. Edit: sorry, just noticed the question is about a 90. My answer is probably not relevant! |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1066 ![]() ![]() ![]() |
Just turn up the radio - should drown out any complaints coming from the rear.
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 202 ![]() ![]() ![]() |
For the forward facing folding rear seats in a Puma (3rd row on a 110, 2nd row on a 90), there is a possibility to remove some bushings in the hinges mechanism to recline the seats further. I reckon I gained about 3 to 5° angle between the seat base and seat back in doing so.
Not a world of a difference, but every little help as they say. I unfortunately do not have any pic, as this was done long ago. From memory, you need to remove the seat back cover and foam, as well as the plastic part covering the hinge assembly on both sides of the seat. Once done, fold the seat back a few times to understand how the mechanism works and you should realize which bushings shall be removed. For each seat, it's a rubber insert on one side and more of a metal washer that is partly welded around a stud on the other side (just grind it off and remove the metal washer, not the stud). /Mat |
