![]() | Home > Technical > Puma Engine Failure Disaster |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 307 ![]() ![]() |
I’m no LR expert but I know another possible cause is overfuelling resulting in diesel topping up the sump to the point eventually where the engine starts to run on the diluted sump oil. If this happens it will do exactly as you have described and self destruct. I’d imagine if this has happened there won’t be much salvageable and the cheapest option would be recon engine.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2403 ![]() ![]() |
Sounds like the same problem hank had https://www.defender2.net/forum/topic80807.html?highlight=france
Rebuilding a 2.4 seems to be problematic if you read the post. Also options for a new 2.4 or alternative engine are covered. |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 547 ![]() ![]() |
www.mdengineering.co.uk/2-4-2-2-tdci-engines/
motor and diesel above do complete or bare engines from about 3K plus vat |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2338 ![]() ![]() ![]() |
They are indeed identical symptoms to what happened to me a matter of weeks ago! Driving along quite happily then all of a sudden flat out revs, plumes of smoke and “bag of spanners” sounds. I am hoping to get my defender back this week (it has been recovered from France) so look forward to getting into diagnostics. I also suspect injectors severely overfuelling since I had recently fitted a set of new (remanufactured) injectors > 110 XS Double Cab |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Blown turbo seal leading to runaway could be a thought? Roaming around 🇳🇴🇨🇭
Yeah I agree however on this occasion I was able to stop the engine by turning off the ignition, suggesting it was fuel rather than oil running the engine > 110 XS Double Cab
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3572 ![]() ![]() ![]() |
On a common rail, a stuck open injector can be catastrophic. The rail is pressurized all the time, and there would be a lot of fuel going in the cylinder during the intake and compression stroke - where normally it would only pre inject, main inject and post inject towards the end of the compression stroke.
Overfuelling could also cause other problems. Holed pistons is not unheard of. Wonder is the injectors are the achilles heel of the 2.4? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
That would almost suggest that the problem was on only 1 cylinder. Once you cut the power to the other 3 injectors, there was simply not enough power for the engine to keep on running. White smoke is also one of the signs of bad timing on a diesel. Injecting diesel all the time is really bad timing. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Does the 2.4 have an electric throttle body that closes on shutdown? (Sorry im only familiar with the 2.2 which does have said throttle body) Roaming around 🇳🇴🇨🇭
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 337 ![]() ![]() ![]() |
No throttle on the 2.4
Tractorman Member Since: 08 Jul 2016 Location: Inverclyde Posts: 41 ![]() ![]() ![]() |
Many thanks for all of the replies guys - much appreciated. Jim
Have you seen hanks post re his issue in the post I highlighted above. His may well be down to a vcv or over fuelling injector causing hydraulic lock as you highlighted tractorman . So all may not be lost, the engine may not be blown.
Indeed - see here Tractorman https://www.defender2.net/forum/topic80807-50.html > 110 XS Double Cab
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5297 ![]() ![]() |
I think that happened to my mates dads jag, Sucked all the compression out of the engine, which ended up killing the engine. The car ended up been a tin of beans. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
