Home > 130 > Another 130
Skeggy 90
England 2011 Defender 130 Puma 2.4 SW Bali Blue
Another 130
Have been Defenderless for a while and have finally pulled the trigger on a 2011 130 2.4 ex SSC double cab.
I have owned an SSC 110 hardtop previously but could not get on with 2 seats and a Foley TD5 130 station wagon that I have always regretted selling.
These SSC vehicles have loads of lot fitted, winch, inverter, cabin heater, roof rack
Hopefully picking it up later in the week.
Not sure if I am going to keep the box on the back yet or just modify it inside.
 90 300 TDI SW (sold)
130 TD5 Utility (Foley SV) (sold)
110 TD5 Hardtop (sold)
110 TDCI Utility (sold)
1st Edition Range Rover Sport Supercharged
Velar P380 HSE
Discovery 1 V8 auto
Puma 130 Double Cab (sold)
R35 GTR
Defender 110 300 TDI CSW (sold)
2010 110 XS Utility
Post #929360 11th Nov 2021 12:09am
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
Congrats, looks very similar to my western power 130 when I got it, nearly 3 years ago now..
Keep us posted..
Cheers alex 98 300 tdi 90 project
88 200tdi project soft top
96 disco 1 jap import
79 911 sc
08 130 double cab utility
Post #929361 11th Nov 2021 1:40am
familymad
The golden years of Defender. Used to see them all around heading to work and looking used but loved. Now it’s Toyota pickups hat have taken that marketplace and LR gives the people what they want Whistle 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #929365 11th Nov 2021 8:55am
jst
Nice, I converted mine with hard top rear, still Impressed with its ability to load carry and carry people in comfort.
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #929366 11th Nov 2021 9:09am
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
I’ve got an ex-SSE 130 pretty much identical, even has VO61J** reg no.
Have you worked out the electrics yet?
Had mine two years and there’s still a button that I don’t know what it does.
One of the first jobs I did was pulling out the hydraulic system. I was never going to use it and it removed a huge amount of weight.
Mine has been faultless (apart from all the body rattles and squeaks)
 2011 130 Utility Body
2005 110 Van
Post #929384 11th Nov 2021 12:26pm
mwestcrew
Although on a second look at yours I don’t see the hydraulic spool outlets on the bumper. 2011 130 Utility Body
2005 110 Van
Post #929385 11th Nov 2021 12:28pm
JOW240725
So want a 130! All look great! James
Instagram @suffolk_rovers
Post #929432 11th Nov 2021 8:51pm
Skeggy 90
That’s what my one will look like after stripping the top layer of blue paint off to reveal the green. Takes ages I had to do that in my 110 I know what you mean about the buttons not sure what the one on top that makes a clicking noise does. Have you got an inverter on yours and mine hasn’t got the hydraulics. 90 300 TDI SW (sold)
Velar P380 HSE
Discovery 1 V8 auto
R35 GTR
2010 110 XS Utility
Post #929434 11th Nov 2021 9:21pm
Skeggy 90
Keep us posted..
Cheers alex
Has yours got second row seats or is it stripped out in the back. 90 300 TDI SW (sold)
Velar P380 HSE
Discovery 1 V8 auto
R35 GTR
2010 110 XS Utility
Post #929435 11th Nov 2021 9:24pm
Skeggy 90
My old 110 SSC
Velar P380 HSE
Discovery 1 V8 auto
R35 GTR
2010 110 XS Utility
Post #929437 11th Nov 2021 9:28pm
mwestcrew
Mine has an inverter and two additional batteries in the box body.
Big black button to left of heater controls connects auxiliary batteries to starter batteries while you hold it pressed. It’s to help start if you run the main battery low.
I also have a red push button to the right of my heater controls and I still have no clue what that is!!!!
I managed to work out how to remove the CAN bus interfaced speed limiter as Speedo 70 on the motorway was a real pain.
There are so many electrical additions on mine, I am a bit nervous that one of the add ones is going to cause a problem in the future 2011 130 Utility Body
2005 110 Van
Post #929454 11th Nov 2021 11:05pm
Skeggy 90
Has yours got a reverse camera and one on the towbar. I could not get the tow bar camera to work on my 110 the reverse one worked fine. The 130’s drive much better than the other Defenders in my opinion but mini roundabouts can be a bit tricky. 90 300 TDI SW (sold)
Velar P380 HSE
Discovery 1 V8 auto
R35 GTR
2010 110 XS Utility
Post #929459 12th Nov 2021 12:06am
alwoodley72
Mine was stripped out, bulkhead, Heater, inverter and battery.
I ditched all the wiring as someone had made a terrible job of removing/ ‘improving’ it, and since fitted rear seats on a custom seat base that I’ll put drawers in. Need to get the rear doors opening further, then fix the bodywork ‘triangle’ to the door for a nice square opening for the drawers. I can remove the seats pretty quick to put my fridge in
How do you remove the speed limiter, the guy who mapped mine said it would be a box in the loom under the dash? I need to get in there for my heated seats/ screen wiring at some point, soon!
130s are the most comfortable Landy, and by far the best towing vehicle I’ve driven, love mine😀
Mine at the moment….
79 911 sc
Post #929460 12th Nov 2021 12:25am
mwestcrew
My speed limiter was interfaced to the canbus and was a stand alone device inside the drivers side seatbox. Mine was made by VDO I believe. You'll know it's the right box if it's there as it has a wire and lead seal. 2011 130 Utility Body
2005 110 Van
Post #929497 12th Nov 2021 3:28pm
mwestcrew
Mine does have that system and before I tried to clean the main camera and killed it (!) you could swap between cameras using a button on the monitor, the only problem with that was it went back to the main camera if reverse was selected. Somebody told me in my research to find out what the big red push button on the dash that it swapped cameras. Have never made it work though 2011 130 Utility Body
2005 110 Van
Post #929498 12th Nov 2021 3:39pm
