Home > Maintenance & Modifications > Rear shock lower bush/washer set up
excossack
Aiming to replace the rear shocks today if it doesn't rain.
What is the correct order/set up of the washers and bushes
The washer and bush at base of the shock came like this from LR. I have added the bottom bush/washer & nut
1999 td5 110
Pic 1
Bottom bush dome side down
Pic 2
Bottom bush dome side up
The bottom washer looks to be the correct orientation according to the parts diagram i found but the diagram does show additional washers I don't have. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #928868 7th Nov 2021 10:49am
dorsetsmith
Pic 1 as long as you have two metal cups on axle ( but if you have no metal cups on axle lower bush are wrong type )
Post #928873 7th Nov 2021 11:27am
Dinnu
Just a note on the top washers (chassis bracket end), the convex side of the washers should facing the bush. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #928874 7th Nov 2021 11:33am
dorsetsmith
^ Thumbs Up misted that
A first washer on and large hole the fit over shoulder but with flat side facing chasse ( B ) next with flat side facing out
Post #928882 7th Nov 2021 12:02pm
Ianh
I have the cup setup on my axle as per the picture above and about to replace the lower bushes for first time so have a couple of questions I expect it’s easy to answer.
1.What’s the torque figure for that lower nut ( I’ve seen conflicting values)
2. is torque easy to apply with a standard socket or does the piston rod need to be held in place via the square section on the end to stop it rotating.
NB:if piston rod needs to be held in place I can resolve this by fitting a crows foot spanner at 90 degrees on my 1/2 norbar torque wrench, thereby maintaining correct torque application, but handy to know in advance so I can ensure I have the correct size crows foot with I/2 inch drive socket. I know I can do it by feel but given I have great torque wrenches I like to use them whenever I can.
Thx Ian
Post #928887 7th Nov 2021 12:13pm
dorsetsmith
upper and lower 37Nm or 27lbf/ft
Post #928891 7th Nov 2021 12:47pm
excossack
Thanks DS.
Your picture shows more washers than what I got with the shocks from Land Rover.?
I was looking at this diagram
Confused now. Sad 1999 Defender TD5 110
Regards
John M0VAZ
Post #928893 7th Nov 2021 1:03pm
dorsetsmith
with the early type rear shock and axle with out metal cups on axle you need the extra wash that locate the bush in to the axle
Early type lower rear shock bush
Used in Chassis VINs from VA998900 to WA159806 (1997 to 1998 MY) and your reg at the cross over point have seen early type axle used on later rages
red line show where axle mounting go in early bash and easher set up
Post #928894 7th Nov 2021 1:08pm
Dinnu
Part number for the shocks are different between early and later axle (as DS stated, for without and with cups spot welded to the axle respectively).
I believe the shocks for the early axles have a shorter stud. They also come with the extra washers that sandwich the axle bracket. IIRC the bushes are also different.
Pictures in 1st post show shocks for axles with cups.
Edit. DS is spot on Thumbs Up 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #928895 7th Nov 2021 1:19pm
excossack
Cheers. I think its all starting to make sense now. Having a 99' Defender will give me the later axle.
Time to get the tools out. 1999 Defender TD5 110
Regards
John M0VAZ
Post #928897 7th Nov 2021 1:25pm
excossack
Thanks all
Job all done. Less than an hour for both side. I had the axle type with the cups built in.
The car now has a less of a jelly like rear end. Lets see how she performs in the rough stuff next week on the Rally Nuts event in Hafren forest. 1999 Defender TD5 110
Regards
John M0VAZ
Post #928906 7th Nov 2021 3:29pm
Ianh
Thanks DS
Post #928920 7th Nov 2021 4:58pm
excossack
Those figures differ from the Haynes manual. ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #928922 7th Nov 2021 5:00pm
