![]() | Home > Puma (Tdci) > Smoking |
| noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196
Yes i had a small screwdriver in there to release the clip but that plug is not moving sprayed it with wd40 still no joy. Yes i have got an obd 11 reader lead and software on my laptop, but guess where the lead is, back at home in Devon, must learn to carry it with me for times like this, but step son brought his girlfriends VW polo round on Sunday with its enging light on so i used it then to check that out.
As long as it gets there it's going in to the dealers Sat morning, i am just very curious as to what can be making this so smoky with out a missfire or horrendus fuel consumption and apart from the limp home modes tonight its driving and towing ok, not even running hot. strange !! If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
| warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903
Hmmm... Big Black has been having a few smokey moments recently too. Very similar situation to yours too. Noticed it a few times driving around town. Nothing as serious as yours sounds though, just noticed a couple of fairly dark clouds in the mirror as I've been driving around - notice it more at night with other cars lights behind.
EGR valve still does the three chucka chucka's, followed by a clunk which I don't think I've noticed before... Like you I also tried to disconnect the EGR, but the plug wasn't up for shifting. No misfire, loss of power, increase in fuel consumption and most of the time it's fine.... There's a nice soot build up on the back of the mudflap too. Again, I'm not sure if it's always been like that or I've only noticed now I've been paying attention. |
| chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897
Interesting and intriguing reading. Hows your exhaust/particle filter? perhaps its damaged
Beer 'n Sex 'n Chips 'n Gravy ![]() |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Defenders, at the moment anyway don't have DPF's
I am surprised about the EGR plug though, admittedly it was a bitch to get off as the plastic lug is not the easiest to connect with a screwdriver. Though if you persist it will come off, It did take me a few goes initially to get it off as it does feel as if it is welded on. The main causes for excessive black smoke emitting from the exhaust are:
Blockage in induction system. Turbo boost pressure inadequate.(TECHNICAL SERVICE BULLETIN No.LTB00254/2010 20 January 2010 Turbo Modulator Service Link Kit?) Defective EGR Valve. Incorrect valve clearances. Poor compression. Blockage in Exhaust system (collapsed baffles etc). Faulty injector. (weak actuator spring, excessively worn nozzle jet, spray pattern: not atomizing the fuel properly, Spindle, pressure adjusting shim, solenoid, etc) Though if it was an injector fault there should be a DTC stored in the ECU as the ECM detects injector faults based on the power consumption of the solenoid valves. Injector pump faulty. Faulty injector pump Volume Control Valve. Faulty injector pump Fuel Temp sensor. ECU fault. Fuelling map. Pressure limiting valve activated. Fuel rail faulty. Faulty fuel pressure sensor High mileage wear and tear Brian. |
Well i had a crap journey home down the M5 Friday night ended pulling onto the hard shoulder 5 times to reset the ecu as it had gone into limp home mode, rest of the time spent tailgateing artics at 55 trying to hide the fact it was me leaving clouds of smoke everywhere.
Saturday morning up to Matfords and good thing at the bottom of Telagraph hill it went in to limp mode again so i left it, and left it running when i got there so the fault was still active. Me and Mrs No worries had a walk down to the Toyota dealer nearby and she sat down to watch the Rugby (how civalised with a free coffee) while i got all the stuff to service her Rav 4 before the winter. Back to Matfords to be told that my exhaust manifold has cracked right through in half (that will be the 4th) and it is melting all the loom, and the maf is out of range. Had a little chat with the forman to note my displeasure as the vehicle was in for service 4thou ago and i complaind about a rattling noise from the exhaust and they replaced the heat sheald shurly would not have taken a rocket scientist to notice the manifold underneath. Any way no courtesy vehicles with tow bars untill the 25th or i could have a Peugeot 207 on the 17th thats poor, so i have sorted vehicle cover on Tuesday one of my team can pick me up and take me back as we are working local Tuesday, all in all a right royal pain in the arse. If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
| wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581
So what is causing the exhaust manifold to crack? Poor (re)map? Blocked cat? MAF sensor causing poor fueling?
I tow heavy things all the time i think they cant stand the heat, i have had 2 turbos sieze up as well and numerous heat shelds If everything is under control you are not going fast enough.
There is a custom stainless steel exhaust company opposite me. Maybe I will mention it to them and see if they can come up with a prototype solution. Fancy being a guinea-pig?
Might take some time though as they are always busy. |
If i was keeping the the vehicle long term yes but as its replacement is going to be 12 plate Mar 12 ive just got to get it through the winter then its being retired to the bosses farm. If everything is under control you are not going fast enough.
Right tthe Land Rover went into Matfords today, they replaced the exhaust manifold, had to weld the exhaust flange back on the downpipe/cat, on the list was also a maf any way got the vehicle back tonight and got as far as Exeter Airport on the A30 and smoking was back as bad or worse than before, tryed to keep going as the equipment on the trailer was needed for Wed am in Harrow London. I aborted the attempt and will take the Land Rover back in the morning and will try to get something to get the trailer up to London asap to get the lowloader unloaded.
Deep joy !!!! If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
| Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479
Sounds like what I had in my focus. Inlet manifold cracked and it resulted in loads of smoke.
Right then smoking update,
When i left home on he Wednesday morning the 90 ran ok all the way up to Exeter it was only once i was on the flat running on the M5 and throttled back to a cruse that the exhaust started smoking badly again, at 1 point i thought it had cured its self and i was going to get up to London late but can't be helped as they say. I turned round took it back to Matfords and fair play i un-hitched the trailer and straight on the ramp, plugged into diagnostics and the ecu would not talk to it. A few goes later turbo underboost fault shown but and a big but the code was not a Defender code so lots of scratching heads. I had to sort my self out a set of wheels and carry on with the day job, Matfords did not have anything with a towbar so i started to phone round. SHB 4X4 needed over 24hrs to set up an account for credit checks ect, enterprise head office were less than helpfull, Thrifty only do towbar Warriors to the military not to the public so itryed the local office of Enterprise as i know they run the Land Rover assistance fleet, yes they had a Disco 4 in stock with a tow bar, a few hoops to jump through re insurance cover notes ect but soon all sorted. Back to Matfors to collect my trailer and the 90 was off the ramp and parked up, asked when i migh get it back they said Friday as they found 2 small vacume hoses split sending false signals to something they did not tell me what but the hoses will be in on Friday and i will pick t up on Saturday. So meanwhile i am floating about in a lovely Disco 4 SV HSE nice !!! not going to wan't to give it back, towes the Ifor a dream so powerfull and smooth, got to admit though towing in central London i certainly noticed it's a lot bigger but the excellent steering lock makes up for that. If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
I don't want to give the D4 back rather taken with it
Haha I get like that whenever I get a courtesy car... Then as soon as I sit back in the Defender it all goes out the window....
