Home > Faults & Fixes (L663) > Adaptive speed limiter |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
Anyone before the dreaded trip back to the dealer, to be told that’s how it works Mike
2nd Nov 2021 11:35pm |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 782 |
If you are enabling in the Pivi menu then it should be a "saved" option. Ours is disabled due
to the inherent number of School Zone time of day restrictions and "advised limits" for bends and such like.. it has always remained "off" so assume if you set it to on, it should stay that way when you start the vehicle. yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
3rd Nov 2021 1:01am |
Thanks thats helpful and exactly how the disco works, except the disco, once enabled on Privi you actually cycle through adaptive cruise, adaptive speed and normal speed limiter...but same principle.
The dealer say you had to enable it each time...but i could tell the service guy was trying to fob me off - thats what they are trained for, hence checking this time before i go back thanks Mike |
4th Nov 2021 8:50am |
TRGRichie Member Since: 03 Mar 2021 Location: Yorkshire Posts: 180 |
Sounds like by pressing the can button for 3 seconds it will select adaptive speed limiter?
Click image to enlarge L663 90ht |
4th Nov 2021 11:02am |
Yes this is sort of my problem, i first have to enable it from the privi menu to then do that...have i pressed the button long enough, its a good question, ill try that again Mike
4th Nov 2021 11:50am |
martinf Member Since: 30 Nov 2020 Location: Sussex Posts: 96 |
It only works if the traffic sign recognition system is operating. Have you checked that it is switched on?
4th Nov 2021 12:48pm |
Here are the relevant pages from the Handbook which may help |
4th Nov 2021 1:02pm |
Thanks all
when enabled it works (although the traffic sign is a good point), but the steering wheel button does not turn it on unless ive gone into the privi setting menu first, thats then required each time i restart the car I have got to try the 3 second press as suggested On the discovery you enable on the privi menu once in the vehicle life then its set and never go in again if that makes sense Mike |
4th Nov 2021 2:17pm |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1038 |
You won’t keep it on for long! Mine slows me down to 20mph when passing junctions, if the sign is visible from the main road. Dangerous IMO. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
4th Nov 2021 5:46pm |
Admittedly i use adaptive cruise more, but speed limiter i use it all the time, it works now - i just have to go through 3 or 4 steps to get it on for the journey.
When working its great, the only issue i have had was not detecting the smart motorway, so not dropping my speed. Just for information, if you push the accelerator to the floor it will auto over-ride the speed Mike |
5th Nov 2021 1:35am |
Took it for a spin today and the only way to get it on was to go into the master privi menu and turn Adaptive on, then the steering wheel button turned it on, otherwise its just toggling between cruise and normal speed limited.
They will have to have it back for another time Mike |
6th Nov 2021 2:00pm |
Even with the long 3 second press? L663 90ht
6th Nov 2021 5:11pm |
Yes, just toggles between cruise and normal limiter, until you enable it in the menu each drive.
Not like the disco that then allows you to go between each option Mike |
6th Nov 2021 7:01pm |
Loafer Member Since: 29 Jun 2021 Location: Kent Posts: 25 |
Just tried this on a journey and got it to work…
Click + to set a speed and then the top right button to toggle from Limiter to Cruise. Then, to move from fixed cruise into adaptive cruise, press and hold the gap adjuster button. Carpathian Grey 110 D300 HSE |
6th Nov 2021 10:18pm |
