![]() | Home > Puma (Tdci) > 2nd crack - Oil Filter Sandwich Adaptor |
Gazza130 Member Since: 12 Aug 2020 Location: Darwin Posts: 8 ![]() ![]() |
Hi all - still seeking advice. Want to install some gauges including oil temp and oil pressure. So looking for an adaptor or sandwich plate for the oil filter to give me ports for fitting the gauge sensors. Have the standard oil filter with black housing and replaceable filter element.
There's lots on the web but cant be certain they will fit - can anyone recommend the better quality ones to for the Puma 2.4 and the relevant specs I should be looking for? The gauge connections are standard 1/8NPT but want to make sure the adaptor will fit and won't leak! (Got enough of those ![]() Thanks in anticipation! Gareth 2010 Dirty 130 Darwin, Australia |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
I think but am not sure that if you change to the 2.2 spin on filter arrangement you will have lots more options DEFENDER 90 TDCI XS,
Thanks I'll look up that option
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2510 ![]() ![]() |
This topic may help https://www.defender2.net/forum/topic78318...oil+filter
PeeWee Member Since: 13 Apr 2017 Location: Somersetty Posts: 19 ![]() ![]() ![]() |
Ah, that looks easier! And yes, I would use OEM parts rather than fleabay.
Thanks PeeWee |
