![]() | Home > Maintenance & Modifications > Exmoor Trim Carpet and SeatBoxes... |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
When I tidied up an old 90 a few years ago I carpeted the bulkhead on the rear face as part of doing the whole of the load area. If I'd kept it longer then I would have done the front, too as it makes a real difference to the feel of the interior.
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
karlp606 Member Since: 19 Aug 2021 Location: Hull Posts: 302 ![]() ![]() ![]() |
Was that just with the some general charcoal carpet?
glpinxit Member Since: 31 Jul 2010 Location: rural Somerset Posts: 159 ![]() ![]() |
My under-seat access panels fitted over the carpet exactly as per the Exmoor video. (Nothing to say about the bulkhead as mine doesn't have one.) Cheers, Guy.
How did you slide them back in? There seems to be no space or give in my carpet? Everything lines okay with the seat bolt holes.
They fit perfectly underneath the seat box flap but not over the edge of the seat box where the holder clips in place. |
I'll try and remember to take a photo or two tomorrow. (When it is daylight and the Hallowe'en mob disperses.) Cheers, Guy.
That was 'Veltrim' carpet, which is a strange stretchy material specifically for lining vehicles. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
![]() Click image to enlarge ![]() Click image to enlarge
Here you go... The front edge of the lid goes over the carpet and is held down by the clip while the sides and back go under it and the rear is retained in the channel- as it was originally. This means the carpet can't be glued to the seat box where the lids slide under it but the front can. Cheers, Guy. |
Thanks for that - I'll have a look at mine when Im home.
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 358 ![]() ![]() ![]() |
I used 4 way stretch carpet stuff on that bulkhead area - suspect veltrim mentioned by LRA is the same stuff. Pretty cheap on eBay with spray adhesive and looks good.
Looks like I made a boo boo! Will have to try and angle out the lids as Ive done my under the carpet! And after been away for a few weeks, the cold weather has killed the battery so will need to get to the battery to charge it tonight. The channels for my lids do seem really stiff, can you make them slightly wider by prying them open more? |
