![]() | Home > Puma (Tdci) > land rovers that use the same diff as rear diff on puma 110 |
| Sam smith Member Since: 12 Aug 2021 Location: Suffolk Posts: 81
hello
does anyone know what other landrovers use the same diff that is found on the rear of a puma 110? thank you! |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038
Disco2 uses a Rover-pattern long nose diff which won't fit a Puma LWB rear axle. As far as I know the P38 diff was only ever used on P38 front and rear, so nothing else provides a donor source (except another LWB Puma).
The P38 diff was made in both 2- and 4-gear versions but fours are hard to find. Twos are easy to find and cheap and provide a.great basis for a locker build. |
ok thank you
that was my concern. im struggling to find a used rear diff at a reasonable price. any ideas as to where i could find one. Ive tried multiple breakers but no luck yet many thanks |
so would a 4 pin RR p38 rear diff not work in my puma 110?
cheers |
| ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 264
Yes that would fit Dave
It is not at all easy to find a four-gear P38 diff in my experience, but you can always buy a two-gear diff (which is much easier to find and cheaper) and rebuild it with a Ashcroft ATB or an Ashcroft four-gear centre. This may even work out less expensive. Worth bearing in mind as an option.
A quick look on Ebay reveals stacks of two-gear diffs at prices from £90 to £140, and a couple of four-gear diffs at £240, and another four-gear at £350. |
Ok great thank you both so much for the info! That’s a great idea I shall look into that
| All times are GMT |
