Home > Puma (Tdci) > Heated rear screen..
RED-DOT
My 2007 90 has a heated rear door window that the top 3 elements have bever really worked and i complained about it under warranty and the garage said i must have damaged it... no problem but it was in for a MOT on Monday and i got a call to say my high level brake light was inop due to it sharing a feed/earth throught the element sandwiched inside the glass which now appears not to be broken at all. I called LRCS and they know nothing of the bad batch of rear screens but i am sure i read of it on here, Anyone remember the thread as i believe there is a service bulletin regarding faulty units? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #92742 5th Oct 2011 8:45am
DAZ110
High level brake light rubs through the glass electrical element. I had to run a wire up the side of the glass(tucked behind the rubber) to the brake light to get it to work again. My 3 elements for the heated rear screen are not working either. I have posted about this before so look up my posts and you will probably find more details.
Post #92744 5th Oct 2011 8:53am
Grockle
faulty batch of windows don't know if LR will still cover it under warranty 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #92745 5th Oct 2011 8:58am
dgardel
Italy
Re: Heated rear screen..
I do same diggings on the rubber to avoid the contacts from rubber the heater elements and and now, after 2 years is still OK
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #92757 5th Oct 2011 10:25am
RED-DOT
So again it is a case of "they all do that" and not a bad batch as i recall. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #92759 5th Oct 2011 10:46am
Happyoldgit
Not 100% sure but I think the bad batch I read about may have been front screens. Steve.
http://forums.lr4x4.com
Post #92765 5th Oct 2011 11:17am
Grockle
no it was the rears,we had ours replaced under warranty as did quite a few others 2.4 90 XS
Post #92775 5th Oct 2011 12:56pm
Happyoldgit
Ah right Thumbs Up Steve.
Post #92776 5th Oct 2011 1:10pm
pom
would there not be a TSB if this was a knows issue ? Maybe someone with topix could check.
Pom
Post #92781 5th Oct 2011 2:28pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Both mine were replaced under warranty. The rear for a known issue with the brake light rubbing the element BM52
Post #92803 5th Oct 2011 4:58pm
Grockle
insulation tape over the wires stops it re occuring Thumbs Up 2.4 90 XS
Post #92895 6th Oct 2011 7:33am
dgardel
Italy
Lastest rear glass are differents, new routing outside rubber zone for the heating elements ...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #92896 6th Oct 2011 8:02am
