Home > Puma (Tdci) > Photo of front Anti Roll Bar routing needed
Gasket
I’ve scoured Google images with no joy.
Would anyone be amble to take a few shots of the front anti roll bar on their Puma?
I’ve just noted that line has been put back on incorrectly (bar running under the drag link not over it).
I need to nip out this evening and correct it and it would be very helpful if someone could share a few pics of the bar’s routing with the drop links in shot.
Thank you.
Post #927666 29th Oct 2021 9:09am
iforland
United Kingdom 1986 Defender 90 200 Tdi HT Arles Blue
Does this image help?
[/img]
Post #927671 29th Oct 2021 10:12am
Gasket
I'd actually seen that one and discounted it as it seemed aftermarket.
But, if that is the same layout (with the same curve in the ARB) as an OEM setup then its actually a lovely clear image so I can confirm the correct routing.
Post #927672 29th Oct 2021 10:22am
iforland
Interesting, never really thought about the routing, but I guess your's looks like this:
with the roll bar going under the track rod, rather then what is shown in the first picture I posted and also another one I found below
looks like it depends on the direction of the links connected to the axle
Post #927674 29th Oct 2021 10:45am
Gasket
Between all the photos above - that's great thank you.
Yes, exactly as described above, the 90s been in for some work and it looks to me like the ARB has been replaced upside down (note the ends curve up not down) and then the drop links now connect down from the axle not up off it.
No great drama, I'll just remove and swap it - the new nylocs arrived this morning.
So plan is: disconenct drop links from ARB. Remove ARB alltogether. Flip ARB over and reconnect drop links and mounting bushes.
Here's how it currently looks. To be fair, if you weren't used to Land Rovers as the garage weren't it actually looks like a perfectly sensible way of doing things,
here's some pics of it before I go and correct it:
Post #927675 29th Oct 2021 11:06am
Dinnu
Yes, you will need to flip the ARB.
I would also suggest you try it out without ARB altogether. I found the ride much smoother without the ARB. And articulates a bit better at the front when offroad. It rolls a bit more around roundabouts though. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #927676 29th Oct 2021 11:22am
Gasket
Thanks everyone. Bar now flipped and working perfectly.
Post #927890 30th Oct 2021 11:57pm
