Home > Maintenance & Modifications > LS3, Tremec G.box and Puma
Caterham
so for obvious reasons I have absolutely no faith in the adapter shaft not letting go just when you need it the most.
I'd also like to have an LS3 V8 at some point (but probably won't happen, but....) so it lead me to think could this be a 2 phase conversion.
Is it possible to put a 6 speed manual tremec between the 2.4 puma and transfer box and then perhaps at a later date swap out the puma for an ls3 without having to swap out the gearbox and would the above do away with the adapter shaft?
as they say anything is possible, BUT how practical is the above?
Post #927363 27th Oct 2021 4:43pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Logically it has to come down to how likely you are to fit an LS3? If its a 50/50 then you could end up with a hefty bill for another (albeit nicer) 6 speed gearbox without much benefit.
If you're concerned about the output shaft then I'd suggest swapping that out for a one piece and getting good use out of the MT82/TDCi whilst you prepare for the LS3/Tremec swap.
You could always fit the LS3 to the MT82 then save up for when you inevitably blow the MT82 up. Rolling with laughter 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #927417 27th Oct 2021 9:06pm
Caterham
Laughing
that would be the more entertaining approach. looking for reliability tho.
bottom line though - can it be done. ls3 to mt82?
Post #927513 28th Oct 2021 9:49am
Caterham
/\ got that wrong.
can any confirm if the mt82 can be 'swapped' out for the tremec 6 spd manual and do away with the adapter shaft?
Post #934241 19th Dec 2021 3:06pm
If you are going for an LS3, go for a 6L80E. I’ve driven three with them, one only last week and they just are sublime. QRZ 2e0vpf
Post #934314 19th Dec 2021 10:11pm
Likeomg
For a t56 to be converted the bill is £6,670.
Post #934391 20th Dec 2021 4:13pm
Caterham
Like OMG.
could you expand a little on your comment please.
ref the t56 what do you get for your £6,670?
Post #934433 20th Dec 2021 8:09pm
Likeomg
Rakeway's conversion cost
Post #934438 20th Dec 2021 8:19pm
Caterham
Thumbs Up
so t56 to lt230 - not problem.
what about t56 to puma ?
thank you.
Post #934439 20th Dec 2021 8:24pm
Likeomg
Oh got you...
Im not sure, I only looked into LS3, puma going the distance.
Post #934441 20th Dec 2021 8:28pm
Caterham
in all honesty LS3 is a pipe dream....unless the puma gave up.
in the meantime I have absolutely no confidence in the adapter shaft not giving up at anytime and as such have would not consider planner a journey what I might be a little off piste - which is a little ironic considering what the defender is all about. Big Cry
hence the line of thought - can an t56 replace the mt82 / adapter shaft?
my line of thought be ls3/t56 replaces - pumpa, mt82 and adapter shaft.
plus I'm a step in the right direction should an ls3 ever become a possibility. Thumbs Up
Post #934446 20th Dec 2021 8:57pm
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
No one has ever replaced the MT82 alone with a Tremec. It would be cheaper even if that was to work to just replace the output with an aftermarket unit.
There are companies that will make one off adaptors for stuff like that (you will need an adaptor for the engine as well as the transfer box keep in mind) but the cost will be sky high for a one off setup that probably won’t be very popular. The MT82 is pretty well proven with just the output being replaced and can take a good beating already comparatively. That’s only based on seeing a lot of high torque M57 conversions. 4.0 V8 Defender 90
My Instagram
Post #934471 20th Dec 2021 10:31pm
Mother superior
Stuff a LOF output shaft in there for 300 notes and give me £6,370 Oh woe, oh woe
My crusty old landrover,
It will not go.
Post #934507 21st Dec 2021 10:02am
Caterham
I agree in respect of the '82 being well proven - its just the pesky adapter shaft. I have zero confidence in it. I get it there are options out there to 'improve' on it but at present I'm reluctant to believe the entirely solve the problem. Yes they may only be a few hundred pounds to buy but when you consider the cost of the overall job ie incl labour it suddenly becomes quite a lump of cash. How exactly that compares to going down the route of a T56 (if thats even possible) is difficult to say - sure it'll be more but there will likely be a notable value associated with the sale of removed low mile mt82. most importantly the cost of peace of mind by having a proper solution to the adapter shaft - priceless.
Post #934608 21st Dec 2021 11:27pm
Co1
Here’s a thought to ponder. The output shaft failure is often attributed to misalignment between the gearbox and the transfer box. If it is your transfer box that is the problem then fitting a new gear box could have no effect at all on output shaft longevity. It’s probably worth clocking the output side of the gearbox to see whether the issue is there or not.
Post #934619 22nd Dec 2021 7:06am
