Home > Maintenance & Modifications > Auxiliary Gauges Help
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Does anyone have any experience with fitting digital oil pressure and water temperature gauges to a Td5?
I’ve had some extra gauges fitted and they’re not all reading as they should.
Boost and EGT are spot on.
Water temp is reading 95-115°C consistently. I’m going to compare this against my Nanocom to see if the engine is running hot or the gauge is misreading. If it is just misreading, would it be a simple case of a new sensor?
My oil pressure gauge has a mind of its own. On start-up it gives a semi-reasonable figure, before just dropping off. Driving yesterday it had a total fit, going negative at points. So I know it isn’t actually poor pressure. Will it be a case of replacing the sender?
Finally, my CAI/Smiths Td5 tacho is indicating an engine rpm that is always about 250rpm above what is actually happening. So idle is showing 1,000rpm, not ~750rpm. Ideas on how to calibrate this?
Thanks in advance! Bow down Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #926870 23rd Oct 2021 4:07pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
How about using an OB2 reader and a free program like Turbo - lite ??
I know that this works with a puma but may also work with TD5 ...
just a thought Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #926881 23rd Oct 2021 5:15pm
BaronDefenders
The gauges are fitted now, and I’d quite like to get them working. I know others have had success.
I have a sneaking suspicion Td5s aren’t OBD2 compatible . . . Charlie
2002 Td5 90 (SOLD)
Post #926884 23rd Oct 2021 5:21pm
