Home > Maintenance & Modifications > Motul 300 in a TDCi gearbox, transfer box, AND axles??
Matt110
So firstly, top notch service from OPIE oils as always, and free and knowledgeable advice always given and gratefully received.
Sounds like Castrol's a bit hard to come by at the minute for all the known reasons. So I was having a webchat with one of their agents, who suggested I could in fact use Motul 300 75/90 in all three of gearbox, transfer box, and axles, and that despite the viscosity being 75w90 not 85w90 that because it was a much much more modern oil and thus appropriate for the axles and potentially protects them better.
Given the age of Castrol EPX as a product - i am perhaps not surprised. I'm OK putting a stone age product in a stone age design of diff, it's a fairly simple thing. But having lost one transfer box under warranty probably due to heat exposure on a french motorway, I would be really interested if it was better protection for the transfer box.
Doing the Motul would be a truely horrendous costly exercise, but I wondered if anyone had ever used it as above, and if so, what are your findings.
I've got Motul 300 in my TDCi gearbox and I think it shifts slightly better when cold, but that may well be placebo. It certainly wasn't cheap stuff.
Again - absolutely not questioning OPIE here, just looking for whether others had done it, and what you found if you had.
Post #926480 20th Oct 2021 10:37am
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Not used Motu before but recently, after a chat with one of the Opie advisors, I used Red Line oil in my gearbox and transfer box, along with Castrol TRANSMAX long life in the diffs. Since the fluids change I have never driven a Defender with such a smooth gear change….
Gearbox - Red Line MTL
Transfer box - Red Line 75W90
Diffs - Castrol TRANSMAX Axle long life 75W90
Not cheap oils but they make a very noticeable difference in the drivability fo my Defender.
Jim
Post #926483 20th Oct 2021 10:47am
jim4244
I should have added that I have a 1997 300Tdi with an R380 gearbox.
Jim
Post #926486 20th Oct 2021 10:49am
Dinnu
Keep in mind that diffs and transfer box have different requirements to a gearbox... as they do not have synchromeshes to align.
For the diffs, I prefer a thicker oil. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #926490 20th Oct 2021 11:01am
Matt110
I'm absolutely with you - i'd always have preferred a thicker oil. But I've never got into the engineering behind that... why do we both prefer a thicker oil? I've no idea myself it's just a gut feel and something i've always done.
If a more "modern" high shear oil is capable..... perhaps it's just as good. OPIE's thoughts were certainly that way.
I keep trying to find a google test or spec sheet or anything for something like a motul 300 vs a more traditional oil like an EPX as a direct comparison. Nothing really exists that i've found yet.
Post #926491 20th Oct 2021 11:08am
Matt110
Jim
Thanks Jim, Redline sounds interesting. What was the reasons given by OPIE for it being a better oil?
Post #926492 20th Oct 2021 11:09am
Porny
Site Sponsor
I'd also have a look at Swepco Oils.... I run their oils in quite a few Defenders now (and the grease is exceptionally good as well).
http://islubricants.co.uk
Mark is the man to speak to.... IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #926826 22nd Oct 2021 11:55pm
Bluest
I did run Gear 300 in everything for a couple of years with no apparent problems, but it is very expensive if you want to change quite frequently. Instead, I still have it in the gearbox and transfer box, and use the cheaper Motul Gear HD in the axles. I dont do enough miles to know if this is a wise long term choice, but Motul are a proper company and the oil meets the required specs so I'm confident it’s a good choice,
I think, particularly with the axles, any reputable brand will have a good oil for the job. 2007 110 TDCi Station Wagon XS
Post #926837 23rd Oct 2021 7:49am
