Home > Puma (Tdci) > 2.4 puma engine cutting out!??? Please help!!
Nick13
Ireland 2007 Defender 90 Puma 2.4 HT Zermatt Silver
Hi all,
Thank you for having me around!!
I really need some help with my defender 2.4 puma , she is having a very bad case of cutting out while driving so far this is what has been done , changed and reconditioned!
.maf sensors
.css
.cam.s
4 injectors
.fuel filter
.relays.
.starter motor
.stop light switches
The problem happens when the engine is warm and when the accelerator is pressed more than halfway in all the gears!!
Nothing is coming up when plugged in !! I am desperate at this stage !😭😭
Thank you for your help!
Nick13.
Post #926173 18th Oct 2021 11:13am
Likely to be the VCV on the fuel pump with no DTC’s being flagged up on the OBD system.
PF Jones have them, you can change one yourself.
This is purely advice, I cannot guarantee it is that. Do you know how old the original is? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #926176 18th Oct 2021 11:36am
Nick13
Thank you custom90steve for the quick reply, to be honest I couldn't tell you ?? I discovered, after 2 garages that a lot of the work that was meant to be done were actually not done!!! Anyway !! I will look into it !
V.c.v?
Post #926179 18th Oct 2021 11:43am
Nick13
V.c.v= volume control valve!! πŸ‘πŸ‘πŸ˜
Post #926181 18th Oct 2021 11:48am
Nick13
I forgot to mention that when the injectors were put back , the car behave a lot smoother than usual for about 2 days and then the problem came back!!???
Post #926182 18th Oct 2021 11:57am
Nick13
How do you check if the vcv is faulty?
Thanks!
Post #926197 18th Oct 2021 1:35pm
Ianh
If you do end up replacing the VCV here is a little how to from bell auto services https://bellautoservices.co.uk/store/defen...our-valve/
From posts on here you DO NOT need to do points 7 and 8 I.e
7. Using diagnostic system carry out the pump learn procedure.
8. Using diagnostic system carry out the pilot correction procedure.
So a relatively easy procedure, when it first starts after replacement it will not run smooth but take it for a run and all should settle down. Just make sure all is very clean before removal and on fitting new VcV
Post #926198 18th Oct 2021 1:39pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Re: 2.4 puma engine cutting out!??? Please help!!
Nick13 wrote:
Hi all,
.maf sensors
.css
.cam.s
4 injectors
.fuel filter
.relays.
.starter motor
Nick13.
Simple stuff first - is the cooling system topped up and functioning properly with no leaks?
The cylinder head temp. sensor will cut power if it senses overheating - this will happen when the
temp. is shown as normal and will record no faults.
Hope it's this simple Thumbs Up Just because you're offended doesn't mean you're right.
Post #926199 18th Oct 2021 1:55pm
Nick13
Hope it is too!!πŸ˜πŸ˜‰ , thanks ianh for the instructions!πŸ‘πŸ‘πŸ‘
Post #926201 18th Oct 2021 2:00pm
Thanks!
Fit a new one of reputable make. It is impossible to test a VCV, and all you can do is replace it and see if it solves the problem.
VCV faults tend not to produce any DTCs and consequently the main indication of a VCV fault is poor running with no DTCs. A faulty VCV can produce a massive range of symptoms from intermittent misfire, stalling on tickover, poor acceleration, and so on.
Post #926206 18th Oct 2021 2:34pm
Nick13
Thanks blackwolf πŸ‘
Post #926208 18th Oct 2021 2:41pm
Eduardo
VCV are like the butler in the mystery novels.
Always be suspicious of him.... Eduardo
Post #926218 18th Oct 2021 4:51pm
I wonder if the injectors were programmed when installed?
Yes the VCV can often be seen as a cure all, but isn’t always the case but seems to be cropping up a lot lately.
That and grounding issues with electrical problems. _\Hennessey|Venom| F5/___
Post #926249 18th Oct 2021 7:29pm
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Mine did this too,
I changed the VCV valve and it has been fine ever since.
The VCV was only 18months old when I had to change it again.
Fabio
Post #926304 19th Oct 2021 5:52am
custom90steve wrote:
... the VCV ... seems to be cropping up a lot lately. ...
Something I have noticed over the years on this forum is that particular questions and particular faults crop up in waves several years apart. I suspect that this is connected with the turnover of vehicle ownership, with new owners joining the forum and finding the faults that we "old lags" have dealt with in the past.
Unless VCVs have suddenly started getting COVID....
Post #926326 19th Oct 2021 9:39am
