![]() | Home > Technical > Heated seats |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3597 ![]() ![]() ![]() |
Have you tried with a multimeter on Resistance setting and see if you can read any resistance on the seat side connector? If the meter reads infinity ohms, then there is a broken wire on the seat itself. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
dcpallets Member Since: 27 Dec 2018 Location: colchester Posts: 26 ![]() ![]() ![]() |
Ive swapped seat with my own one but still no go
I assumed you swapped driver with passenger. Are you sure there is power supply? You check voltage? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Its a friend landrover with faulty seat, i have heated seats in mine ans know they work. Yes checked voltage, it seems strange it didn't work with my seat base in
Did his seats work on your Defender? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
No it didn't nor did mine in there's. Its a bit odd
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1453 ![]() ![]() ![]() |
Just the base you swapped ?? There’s a thermal cutout in the back part of the seat that the wires break on… then no heated seats lumbar or base. Theres a simple guide on repair on here somewhere. His base might have a burnt out element as well hence it didn’t work in yours |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Check for voltage drop at the fuse before and after connecting, if there is a big voltage drop then there is likely a poor common ground.
Hence voltage present with no load, but with load significant voltage drop. Check the ground resistance too, it should be as close to zero Ohm as possible and usually with most multimeters bleep too. If not or a high reading then poor ground. Turn off power though when doing this step though. Also check fuse is secure, and obviously no blown. As mentioned already you can check the resistance of the elements too, but as you’ve swapped seats I’d say the ground maybe most likely culprit. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
So you mean earth,as in main earth body strap and do you know which fuse it is
