Home > Technical > Loss of drive out of diff lock
Grenadier
Is this my second dreaded Output Shaft failure? Loss of drive coming off a roundabout. Very quiet. No grinding. Instant. Have pulled up in petrol station. Can get drive in both high and low diff loc, but can't seem to engage standard drive. Makes a clunk but not engaging. Thoughts? Clearly need to be recovered. Big Cry Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #925726 15th Oct 2021 8:25am
LR90XS2011
Indeed sounds like the shaft between the gearbox and transfer box, what type had you got? DEFENDER 90 TDCI XS,
Post #925728 15th Oct 2021 8:30am
Could easily be a half shaft.
Output shaft failure would result in loss of drive regardless of whether diff lock is engaged. Darren
Post #925729 15th Oct 2021 8:30am
Dinnu
As LRA said.
Most likely a driving member since it failed in low stress situation.
Pull the dust caps (the flexible plastic caps at the center of the wheels) and probably you would be able to see it. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #925730 15th Oct 2021 8:44am
landy andy
Front diff fail. That’s my favourite to kill.
1st gear, out of difflock, hand brake off, gently up on the clutch. Assume no movement from vehicle, then look underneath and see which prop is spinning.
As said if it was gearbox shaft there would be no drive at all.
Post #925732 15th Oct 2021 8:57am
Grenadier
Found the problem. Walked around the car and saw this. Two guys were hanging around whilst I was grabbing a cafe. Thought they were just looking it over as often happens. I'd already driven without problem for an hour this morning and then immediately after they'd loitered around the Def, this happens. Clearly they couldn't be nicking the wheel with 50 people around and mid morning. Interestingly they were in a battered Freelander, a courtesy car from a LR garage in a the area. Do we think they'd nick the bolts so that I'd break down and have to call them? Some proper f*ckwitery if that's the case.
Post #925733 15th Oct 2021 8:59am
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Any sign of sheared bolts?
I struggle to believe 5 bolts could unthread completely without some help... 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #925739 15th Oct 2021 9:21am
The mind boggles Rolling Eyes Darren
Post #925743 15th Oct 2021 9:31am
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Looks like they were maybe trying to steal the halfshafts but got disturbed? If you don't have the bolts I would take one from each of the other 3 wheels and drive away carefully. Don't leave the vehicle unattended where you are or they may take the whole car, which may be the plan anyway?
Post #925748 15th Oct 2021 10:07am
donmacn
Well, this might be a bit o/t but I’d noticed that I was getting oil on the o/s rear wheel.
Jacked up, wheel off, and all 5 bolts were loose. So a very simple fix, but why??
It certainly “could” be human error. Did I forget to torque them when I checked the bearings last time??
OTOH I have a one piece halfshaft on the n/s. When I tried to fit one on the o/s it would go in, but as soon as it was tightened up, the diff wouldn’t turn. I went back to the halfshaft/drive member on that side.
Looking at it again, now that I’ve had this issue, I did wonder if there might be something out of spec on this hub. I can’t remember the colour of the box it came in, but wonder if it it might just be a couple of mm too ‘thin’. This would allow the one piece halfshaft to go too far into the diff, but might it also mean that the drive flange nuts are bottoming out and not torqueing properly?? It doesn’t feel like it, but who knows.
Occam’s razor does suggest human error though… Confused
Apols if this is too far OT but it was Shroppy’s words that brought it to mind. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #925753 15th Oct 2021 10:42am
Ianh
Worth checking your rear diff oil level ASAP as some will likely have escaped given the half shaft was out.
I do hope none of the bolts were sheared if it was someone trying to steal the shafts or disable the vehicle in a hurry.
Post #925780 15th Oct 2021 12:31pm
Ianh
[quote="donmacn"]
If you take one of the drive flange bolts out you can use a bit of wire hanger or vernier calliper to measure the depth of the threaded hole in the hub and compare to bolt length . That will confirm if the bolts are bottoming out or not.
Post #925791 15th Oct 2021 1:17pm
ickle
Its trying to morph into a Bond car isn't it?
Should open up a few Peugeot door skins a treat!
Keith
Post #925820 15th Oct 2021 5:21pm
landy andy
Would it be the case that you undo the drive flanges, then you can pull/push/tow the vehicle to steal it?
Post #925834 15th Oct 2021 6:18pm
Oldowner
Yes
Post #925863 15th Oct 2021 8:33pm
