![]() | Home > Maintenance & Modifications > Puma alloys to wolf wheels. any troubles? |
No, they're a straight swap. The studs will come up slightly shorter than you might expect but this is exactly how they would have come from the factory for both civilian and military models. It's not an issue as long as the nuts are torqued correctly - 170Nm.
I'm not sure about white wheel nuts ![]() ![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2362 ![]() ![]() ![]() |
Paddocks sell some quite nice closed zinc plated wheel nuts which are not expensive.
HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
big110 Member Since: 02 Nov 2016 Location: Pinner Posts: 374 ![]() ![]() ![]() |
Gosh I love that color mate! So I’m going with white wheels. I don’t think the black nuts would look correct. Any suggestions? |
Black wheel nuts are kind of the standard so I'm not sure that they wouldn't look correct
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2268 ![]() ![]() |
Great look Anorak and black nuts also
![]() Keith |
Thanks Keith. I've moved on from them now, though. I ultimately decided that they were too dark as most of the time you couldn't see the detail and so have gone with body coloured Boosts instead. Darren
RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 693 ![]() ![]() ![]() |
On my 130 have black steel wheels for summer tyres and off white steel wheels for winter tyres, nuts are just as they come ‘au natural’ looks fine on mine, but its a vehicle not a fashion accessory. 130 Puma HCPU with an Artica 240LR Demountable Camper
kaney Member Since: 01 Oct 2018 Location: Bolton Posts: 232 ![]() ![]() ![]() |
I found I got steering wheel wobble around 50mph after changing from boosts to wolf then after investigating I found a few rubber bushes were on the way out and the front swivel seals needed changing but for the difference I never had any wobble with the alloys maybe just coincidence but all is fine now I also swapped the front wheels to the back after doing the seals so I cannot say what caused it but it did show I had an issue with swapping from alloy to steel
Everything one needs to know about wolfs. 28 pages.
https://www.defender2.net/forum/topic55943...preciation |
