Home > Modifications & Maintenance (L663) > Disable auto shutdown? |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2718 |
Anyone know if it’s possible to disable the “auto shutdown” feature? I.e when you stop, put in park and disconnect your seatbelt, and open the door it automatically turns off the car…
Don’t mind it some of the time, but would like to be able to make it not do it when off road - you get out to open a gate etc and have to restart the car, select your settings etc… NB I’m not talking about auto stop/start Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
11th Oct 2021 8:04am |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3748 |
Just been out to my D240 First Edition, started it up, disabled the auto stop/start with engine running, ensured in P, opened the driver’s door and got out and the engine kept running. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
11th Oct 2021 2:58pm |
Thanks- that is indeed what I’m talking about.
Mine is actually a P400e PHEV so auto stop-start isn’t really a thing… Since there’s no mention of disabling it I might have to play around and see if I can “trick” it… Maybe pressing a pedal or something before I open the door will do it. Can just leave it in “HOLD” but that sounds a bit risky off road! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
11th Oct 2021 3:07pm |
If it’s a PHEV then just press the P on the gear selector, I thought that the default on the PHEV (and it was on my Countryman PHEV) is that if there is sufficient charge in the battery the car will pull away in EV mode only so you may have to switch it to EV only mode and press the P button? Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
11th Oct 2021 3:21pm |
No sadly it doesn’t seem to matter what mode (EV/Hybrid/Save) you’re in, the car shuts down any time you have it in Park, undo your seatbelt & open the door…
There isn’t really the equivalent to disabling stop/start in the PHEV… Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
11th Oct 2021 3:23pm |
To be 100% clear I just want to find a way to get out of the car (E.g to open a gate, load something in the boot, attach a trailer) without the car shutting down… Cheers, David
11th Oct 2021 3:25pm |
VinSuz Member Since: 10 Nov 2020 Location: Pennsylvania Posts: 36 |
I don’t like the auto shut-off “feature” either but found an unexpected solution while addressing another issue. I’m a big guy (6’3”, 260#) and hate the short seatbelt receiver, so I bought a seatbelt extender. Now, when I stop to check the mailbox, I unclip the seatbelt from the extender, which remains clipped into the seatbelt receiver. The only problem is I do occasionally forget to buckle-up because I don’t get the reminder chime since the extender is clipped into the receiver. 2020 Defender 110 P400 HSE Santorini Black/Ebony
2019 Jaguar I Pace HSE 2022 Chevy Bolt 2LT |
13th Oct 2021 10:37am |
Tom_T Member Since: 08 Nov 2020 Location: Essex Posts: 87 |
This annoys me greatly as well and would like to be able to disable it. No good for getting out and opening site gates or farm gates. |
13th Oct 2021 6:21pm |
