Home > Maintenance & Modifications > Heater intake drain grommet
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Hi all, washed the Defender this morning and thought it was a good idea to clear the drain in the wing heater air intake, sure enough it was blocked and was holding quite a bit of water, cleared it my usual way by poking it through with finger, unfortunately the whole thing popped out and cannot seem to re attach it in the hole as the access is awkward.
Question, is it really necessary, presumably LR put it in for a reason Question it certainly will now be much less likely to block up now though!
Thanks
Mike
Post #925192 10th Oct 2021 1:04pm
It stops fumes being drawn in from the engine bay so yes, ideally it should be in place. Darren
Post #925222 10th Oct 2021 4:46pm
Mike c
Ok, yes that's a good point, thanks, I will persevere with trying to get it back in Thumbs Up
Post #925224 10th Oct 2021 4:55pm
landy andy
Taken mine out of the three Defenders I’ve had without problem. Fumes come out the exhaust.
Post #925249 10th Oct 2021 8:42pm
Mo Murphy
Likewise, I've never had trouble with fumes. Throw it away and never have to clear it out again !
50 Shades of Pennine Grey
Post #925264 10th Oct 2021 11:50pm
Mike c
Thanks chaps, good to get some different opinions Thumbs Up
Mike
Post #925280 11th Oct 2021 10:13am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
I managed to squeeze it back in with a bit of patience and some long nose pliers.
Post #925338 11th Oct 2021 6:43pm
