Home > In Car Electronics > Custom tablet dash mount for Puma
lolo
Switzerland 2008 Defender 110 Puma 2.4 CSW Keswick Green
Hi all,
I did not find any tablet dash mount that met my requirements so I've built my own:
- Heavy duty, stable
- Fast and easy install/removal
- Hold any tablet size
- Cheap
Pretty satisfied with the result. Might be improved with 2 side M10 bolts to enable tilting, but current tilt angle is OK for me.
Build material:
- base plate: steel 200x60x2mm
- face plate: steel 200x80x2mm
- L brackets: steel 50x50x2mm
- vent inserts: steel 50x30x2mm
- bolts: M4x10, M4x16
- fastenings: velcro tape 200x20mm
Greetings Lolo
Post #925176 10th Oct 2021 10:27am
Dinnu
A tip for you... you can install a dash cam app and have more functionality Thumbs Up 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #925191 10th Oct 2021 12:58pm
Ianh
How does the tablet deal with the heat from the vents behind it during winter ?
Post #925195 10th Oct 2021 1:23pm
Mo Murphy
Very tidy !
50 Shades of Pennine Grey
Post #925199 10th Oct 2021 2:29pm
PCM
oooh. It looks just like a Tesla.
Lovely job. Very Happy
Post #925219 10th Oct 2021 4:23pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
looks very professional. extra points for the Wunderbaum Rolling with laughter
Post #925339 11th Oct 2021 6:46pm
lolo
Should be far enough from vent to not overheat the tablet, so far so good...but I'll get back with a status in January Wink
Post #925806 15th Oct 2021 3:45pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
So velcro and slotting it into the vents is holding it in or have you screwed through the dash? Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #925819 15th Oct 2021 5:20pm
lolo
Just slottet into vent and velco it on the front. That's it, no screws. Very stable. Let's see if induced torque will eventually crack the vent, but so far so good.
Post #925881 15th Oct 2021 10:58pm
lolo
To address the smart question of lanh about how the tablet will hold the temperature of the vent.
Well, it appears that the tablet is not an issue, BUT adhesive of the scratch on the metal plate yes.
Temperature of vent/sun softens the adhesive, and as I only put two narrow stripes of scratch, the weight of the tablet slightly slides the scratch down on the metal plate.
My first solution is to increase surface of scratch, so weight/surface ratio will decrease. New larger scratch is 3M, maybe better quality. Let's see if that works better.
Definitive solution if it does not work as expected: glue scratch to the plate (not the tablet) with epoxy adhesive or put some small screws through the top of the scratch.
Agile/iterative custom product dev Wink
Post #926590 20th Oct 2021 10:08pm
macfrank
Good point. I try to avoid stick-on velcro as the glue always seems to become weaker than the velcro itself eventually... Confused Or maybe I just didn't get good quality. 3M maybe better.
In a recent video of Grizzly n Bear Leigh said they had attached a flexible solar panel to the roof using "heavy duty velcro". I wonder what that is exactly or where to get it.
Post #926608 21st Oct 2021 6:37am
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
Good effort. Thumbs Up
I went the RAM mount way, absolutely brilliant, very stable, can change between cars, very strong suckers, just quite pricy. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #926612 21st Oct 2021 7:45am
Dave T
Opps double post 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #926613 21st Oct 2021 7:46am
Perhaps your mounting plate would benefit from a second plate that's spaced off the back by 10-15mm? The same principle as the safari roof on Series Land Rovers. Darren
Post #926620 21st Oct 2021 8:33am
lolo
Thank you Darren that might be a solution. But may be the cantilever will be too important. Let's keep your idea in reserve should plan B and plan C not tackle the bug
Post #926683 21st Oct 2021 3:45pm
