![]() | Home > Maintenance & Modifications > For those who aren’t married. |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 843 ![]() ![]() ![]() |
I guess it maybe cheeper to get married Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3614 ![]() ![]() ![]() |
By the hub bolt pattern, looks like it is made for a Series, not a Defender axle. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4332 ![]() ![]() ![]() |
That could be true, they do a lot of other series stuff. 2007 110 TDCi Station Wagon XS
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3769 ![]() ![]() ![]() |
It can’t be THAT expensive!! ![]() |
Silver Back Member Since: 11 Jun 2015 Location: Lincolnshire Posts: 409 ![]() ![]() ![]() |
If you think getting married is expensive, wait until you get divorced. ![]() |
Yep divorce costs more than the marriage. You loose things you never knew you owned. Searching for my first Defender...and started just as Covid hit, so talk about timing.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6215 ![]() ![]() ![]() |
Looks like the Tibus unit that G wagens can have.
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
Ooooh its a Portal axle? I thought it was a tool for manufacturing a steel rim, right now I understand why you guys are saying its not going to be cheap.
Their Defendery bits on on: https://www.designdevelopmenteng.co.uk/sho...c115811253 'Reassuringly expensive' but not outragous? 2005 Td5 90 XS 1989 V8 110 CSW |
Curious about these ~ anyone any experience?
Snap Fit Security Bonnet Bush ![]() Click image to enlarge https://www.designdevelopmenteng.co.uk/sho...c115811253 |
I've got a set to fit but not had chance yet. Darren
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17946 ![]() ![]() ![]() |
From what I have seen of their engineering, the stuff from these guys is pretty good. I have one of their modified Disco2 ACE valve blocks to fit on my Disco (not fitted yet) and the workmanship is excellent. I am also lead to understand (by them) that they did much of the engineering behind the LOF one-piece adaptor shaft as well.
If they are now making bolt-on portal kits it is a very interesting development, but don't expect them to be remotely cheap either in price or quality. The general problem with bolt-on portals is that the axle isn't really strong enough for the portals. Tibus has done quite a lot of work to overcome this and it will be interesting to see how D&D address the problem. |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926 ![]() ![]() ![]() |
I have their disc brake conversion brackets on the series and the quality of the machining work is very very nice.
Bryan is a great chap to deal with too, their customer service I can't fault. ![]() |
