Home > Puma (Tdci) > Changing filters
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Changing filters
Hi,
I don't have any warranty since I imported used 2009 110 high cap last week from UK. So want to change the air cleaner, oil filter and deisel filter by my self. I used to have a 300tdi it was easy like a peice of cake but afraid to do the same for the newbie.
Is there any perticular steps that have to go through to change them on puma. I have heard that you need to have a hand pump stuff to change the deisel filter???? Confused Confused . Please let me know. Thanks Very Happy Very Happy
Post #92423 3rd Oct 2011 5:04pm
spudfan
Ireland
Regarding the diesel filter,just fill the new one up with diesel and put it on. Should start first time. Seen the dealer and an independent do it with mine.
Regarding the airfilter. When you change it make sure it fits properly in place and that the airfilter "box" is correctly closed and sealed. Mine was replaced at a service and the airfilter was not replaced correctly and was sticking out through an incorrectly closed airfilter box. I started looking as the engine sounded rough and noisey, probably air intake related. The big issues with a badly closed and ill fitting airfilter "box" is the possibility of water getting into the airfilter and then a disintegrating airfilter sucked into the engine.
The wheel wrench supplied should fit your oil filter housing. Have not done mine but others here have and it is straight forward enough. There are torque settings listed on the site if you want to search for them.
Funny thing, but when the independent from whom I bought the Puma changed my oil filter he used a Britpart one and it leaked a small amount. Brought it back and he changed it for another Britpart one and that leaked too. Brought it back again and made him fit a genuine Land Rover oil filter and had no more leaks. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #92434 3rd Oct 2011 5:47pm
dilukabey
Thank you spudfan. Well described!
Me too thought to buy a britpart kit, may be i will buy a genuine oil filter for that reason!
Today I saw the wire with the socket is fixed on top of the air cleaner box so guess i need to remove it before replacing the air filter? Very Happy
Post #92439 3rd Oct 2011 6:15pm
spudfan
Ireland
I am not saying that Britpart filters are bad, I am just stating my experiece with them. Regarding the airfilter "box", it does help if you have small hands to work with the wire clips! 1982 88" 2.25 diesel
Post #92444 3rd Oct 2011 6:54pm
rossy
Howya Spud
is the diesel filter hidden under a metal casing on the back of the chassis near the offside back wheel ? I've been looking for it and thats the only place that looks like where it should be Confused
Post #92472 3rd Oct 2011 8:51pm
spudfan
Ireland
Yep. Do not go mad when you refit and tighten the metal casing. Mine was so tight I needed a pliers to make the retaining nut turn. 1982 88" 2.25 diesel
Post #92478 3rd Oct 2011 9:06pm
MK
Other choices for oil filter:
UFI 2505700
Mahle: OX339/2D
or the one for Peugeot 1.4 206 diesel Rolling Eyes Puma 110" SW
Post #92529 3rd Oct 2011 11:42pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
best price i found for filters, and i seem to think that they are offering free shipping to forum members at the mo,
http://www.defender2.net/forum/topic7086.html?highlight=service
Mark
Post #92883 5th Oct 2011 11:07pm
