Home > Maintenance & Modifications > Perei LED light question
Page 3 of 3 <123
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
glpinxit wrote:
I used the same full-depth Dun Bri plinths front and rear. The light fittings are a little tight in them and, with hindsight, the answer might be to lightly run round the inside of the plinth lip with the Dremel drum sanding tool. On the front, I profiled the plinths to scribe them in around the edge profile of the front light panels. I think that the photo shows this- I tried the 'stand off' plinths but thought they looked like an awful bodge.
I've used stainless screws (security torx) as they all go into plastic blocks. For those who've observed their plinths stand off the body work- I used the dremmel sander to 'relieve' the flat base of the plinth (and its skirt) where it encountered rivets and the plastic blocks that the fixing screws go into which were causing the stand-off issue.
Hi glpinxit,
Could you show me a pic of the front of your truck with the Perei lights, i was thinking of using them on the front but wasn't sure about the size and now least i can get a perspective Very Happy
Post #924369 4th Oct 2021 11:34am
glpinxit
LandRoverAnorak wrote:
Thanks Rolling Eyes
Sorry, didn't mean that to sound quite so blunt!
And for @shanecl here is a full[er] frontal... (No direct-on pic to hand)
 Cheers, Guy.
Post #924414 4th Oct 2021 3:11pm
shanecl
Ooooh you can't beat a good full frontal,
Thank you sir. Very Happy they look well on the front too, are those the 95mm or 85mm
Post #924418 4th Oct 2021 3:33pm
glpinxit
95mm. Cheers, Guy.
Post #924493 4th Oct 2021 9:55pm
shanecl
Thank you Very Happy
Post #924530 5th Oct 2021 9:14am
lakelander
United Kingdom 2013 Defender 90 Puma 2.2 CSW Orkney Grey
glpinxit wrote:
95mm.
Anybody know if Perei do a led unit in same style and size ( 73mms ? ) as the original UK oe front sidelight and rear stop / tail?
Post #924549 5th Oct 2021 11:34am
They don't, unfortunately. Darren
Post #924573 5th Oct 2021 1:52pm
Page 3 of 3 <123
