![]() | Home > Maintenance & Modifications > One piece half shaft fitting |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2516 ![]() ![]() |
How did it go ? I’m intrigued as to where the problem is / was. I.e a tight fit into the seal or the splines not aligning etc. |
trailbear Member Since: 14 Sep 2016 Location: Scotland Posts: 405 ![]() ![]() |
Turned out the half shaft hadn’t been machined down enough so it wasn’t actually anything that I was doing wrong.
Ian from IRB arranged for a local independent Landrover garage to have a look at the problem and they very quickly diagnosed the issue, the OSR fitted as it should. IRB sent a replacement the next day, however, due to time constraints I have yet to fit it but hopefully I shouldn’t experience any issues. Ian appears to be bemused as to how this has happened as he says he has both supplied and personally fitted many sets of these without issue. I can’t fault him for his customer service and support to diagnose the issue, the only thing I could take away from the whole experience is to make sure that in future I am wearing my reading glasses when using measuring devices. |
