Home > Expedition & Overland > An Anorak's Expedition Trailer
Page 3 of 12 <123 4 ... 101112>
Jack Pads
Finally for this weekend, I've made some jack pads for the rear legs. I was casting around for some suitable plywood offcuts when I noticed the nice plastic jack pad for my hi-lift jack. A few measurements showed that it could be adapted for the circular feet of the trailer legs by removing part of the lip on each side and so I bought another to make a pair:
To remove the surplus material, I turned my pillar drill into a crude milling machine by fitting a 6mm milling bit and positioning the table at the required height.
With the middle of each long side removed, they accommodate the circular trailer leg feet whilst the remaining ends still enable them to be used with a hi-lift:
 Darren
Post #922917 26th Sep 2021 10:11pm
Hitch Lock
Another little job completed this evening was a refurb of the hitch lock. This is a substantial aluminium thing that looks like it's been several different colours in its life, with white being the latest. I gave it a clean up and a rub down, and also attacked the seam around the top on a bench grinder to take off the worst of a 'lumpy' weld. It's never going to be pretty but it's better for having lost some sharp edges.
It was then treated to a couple of coats of etch primer and regular primer:
Followed by a few coats of 'machine yellow' enamel, which will hopefully make it harder to stumble into!
As it's quite large and featureless, it's slightly awkward to pick up and so I decided that it needed a carry handle. In the picture above you can see the two M6 holes that I drilled and tapped into the top face, to which I added a handle made of 25mm nylon webbing, a couple of stainless bolts and some penny washers:
The plate for the underside of the lock was covered with neoprene foam, as were some strategic parts of the inside of the lock itself:
It's ready to go back on the trailer, now. Darren
Post #923112 27th Sep 2021 10:08pm
L110CDL
Nice work as always Darren on the little jobs you have done Thumbs Up
I saw that you had painted the trailer lock yellow, i would of thought that you would of painted it red as your hitch is, i was thinking it would be easier to see than yellow Very Happy ( just my way of thinking ) Clayton.
Keeper.
Post #923270 28th Sep 2021 9:12pm
Heh, heh, I don't think it'll be easy to miss now, to be honest Laughing Darren
Post #923278 28th Sep 2021 9:35pm
L110CDL
It's not del boys " yellow " paint by any chance Rolling with laughter Clayton.
Keeper.
Post #923288 28th Sep 2021 9:56pm
You're showing your age now, Clayton Wink Laughing Darren
Post #923330 29th Sep 2021 7:59am
L110CDL
It does have it's plus's Wink Laughing Clayton.
Keeper.
Post #923791 30th Sep 2021 8:23pm
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Very nice Trailer Darren Bow down Thumbs Up , was it originally built by wigs ( Adrian ) on the disco 3 forum ?
Stew
Post #923938 1st Oct 2021 6:18pm
Yes Stew, that's the one. Darren
Post #923968 1st Oct 2021 9:13pm
stew 46
I remember it from forum camping trips years ago Thumbs Up great trailer Thumbs Up
Post #923970 1st Oct 2021 9:25pm
Finally managed to get a picture of the fitted hitch lock in the daylight and not the pouring rain Rolling Eyes
 Darren
Post #924209 3rd Oct 2021 12:19pm
stew 46
Got a couple pics from a camp we were on prop 5-6 years ish , Chepstow I think
Thumbs Up
Post #924441 4th Oct 2021 6:19pm
Thanks Stew. It looks quite different now with a bigger tent on top and it'll look even more so when I'm done Very Happy Darren
Post #924494 4th Oct 2021 9:57pm
Door Stays
Had a bit of trailer time today and fitted stays to the two largest doors to the fridge compartment and the main storage area. The stays themselves are 600mm long galvanised 'cabin' hooks that you might use for a garden gate but they needed some bracketry fabricating to fit them to the trailer.
The fabricated parts consisted of replacement keeps for the hooks as the standard ones were too big to fit the aluminium trailer framing, and backing plates for the pivot plates as they were to be bolted through the doors:
I lined the backs of each plate with neoprene foam to provide a seal and prevent moisture from getting into the timber cores of the GRP panels.
The new parts are fixed with stainless bolts, each separated from the aluminium with nylon washers:
This is the stay installed on the fridge compartment door. The positioning is determined by the minimum angle that the door needs to be retained at to clear the fridge slide:
The inside of this particular door had a series of spring clips screwed to it for a variety of tools (mallet, peg puller, leg winder). They're going to live elsewhere though and so they've been removed and the holes de-burred ready for sealing. I did however, re-purpose one of the clips to restrain the stay whilst travelling:
The other door is essentially the same except for the positioning, which is slightly different as the amount that the door can open is constrained by the adjacent jerry can holder. Darren
Post #925233 10th Oct 2021 5:59pm
Picked up an absolute bargain this evening courtesy of eBay - two Defender-sized, almost new General Grabber AT3's for £75! These are destined for a couple of Boost alloys purchased from bluebottle of this parish and will serve duty on the trailer when being towed by my Defender Smile
 Darren
Post #925348 11th Oct 2021 8:06pm
