![]() | Home > Puma (Tdci) > Third gear paranoia |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Anyone else find third gear particularly "clunky/clicky" to engage? Is it "normal" after 5000 miles?
Mine just got worse after going to dealers for 3rd handbrake "repair" (failed). Getting paranoid about evil, Matt |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2489
Normally it is the 2nd gear on the Puma. Maybe a problem in the syncro. You are approaching the state where you`ll want a total replacement from the flywheel back to the Tcase. Puma 110" SW
| parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366
My second gear does this most of the time and third gear snatches a little sometimes. A new clutch is in my garage waiting to be fitted.
98 V8 Disco |
I do not think the grinding will be gone with a new clutch (IMHO) Puma 110" SW
| alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513
My 3rd gear is hard to select when cold. Has been since new - now around 25k on the clock.
I just have to take my time for the first couple of changes and then it warms up. Doubt it's a clutch issue. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
| RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 693
No problem with mine in 3rd or any gear, but I'm told that I do leave changing till late, thinking about it 3rd gear is for quite a short time, straight into 4th normally.
Is there any corrilation between rpm and roughness? Ours had "bag of hammers" sound at 2300 to 260 rpm cured by emc upgrade under warranty. 130 Puma HCPU with an Artica 240LR Demountable Camper |
It's strange - no difference cold or warm, sometimes it happens (or not) at low rpm sometimes high. It makes it hard to know what to do. I guess I just have to wait to see if it gets worse (or better?) Trouble is I can't help thinking the |
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626
Let the dealer know.... then it is logged.... i had mine changed it took time for the dealer to except it tho...I went in 10 + times for them to acknowledge it good luck
| Shax Member Since: 05 Oct 2010 Location: London Posts: 391
I called Stratstones today to bookmine in for its 4th gearbox / clutch inspection / replacement episode... The numpty I spoke to claimed that they (Stratstones, main Land Rover dealer) had NEVER heard of any Puma gearbox / clutch problems... Second is a real pig to engage unless I go reallllly slow with the change, third just grinds, and now fourth is starting to get notchy... I emailed Dave Ashcroft a couple of weeks back, and he seems to think the root cause is a dragging clutch and or synchro issue... The Land Rover "service people" I have chatted with seem to think nowt is wrong.. Err, sorry to dissappoint chaps, but summat is fukt, and I want it sorting... Is there a different gearbox that will fit the Puma? ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
Shax don't take there
| MacDefender Member Since: 17 Aug 2011 Location: Caxias do Sul Posts: 16
As some of you, I have my clutch repleced. The new one is softer then the original. ALL the gears seems to engage more easy (for a Defender)...no more paranoia....
Sounds interesting! What year is your Puma? Do you know if it had the old clutch design? Were there any other clutch symptoms? Thanks, Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
My old clutch died in the middle of the road. Defender full of load plus a ATV in the back.
I was going to the beach for a 7 days vacation....really nice. I tried to fit a Ford Transit clutch without success. After 10 long days my new clutch was installed and the gears automatically improved their engaging behavior. I dont know how long this clutch will live, but is definitely a different one. |
Glad you finally had success What model year is yours? Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
